With nissans if programmed in wrong. It will still start a couple time(just for being in programming mode) type of transponder is wrong or other problem.
I've gone through some very helpful DK posts on nissan security codes and I thought I should mention my plight here on DK so I can get help. My nissan only gets key programmed temporarily when I use the 4 digit code (7536) which I got from the Bcm (a4ee7). I suspect that I need to use the 12 digit code to succeed but I can't seem to locate the glove box sticker mentioned, on the glove box I can only locate engraved nissan and CalsonicKansei logos with numbers: 68500 CN000 on top and P10310A06000 (bottom). could one of these be the security number? I could send pictures if only I knew how! Can you help me through that bit as well?
Thanks mate, it makes one feel much better when someone utters even just one word! You are right! I was programming it wrong and I was convinced the car was stoopid! It breaks my heart now that I realise who was stupid all along! Right now I have trouble programming the key card / remote, I'm using the T300. Any ideas how to go about it? Thanks in advance 912secured, I appreciate it. Wouldn't it have been nicer if those with the same problem as mine chipped in?
