Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: BMW MULF repair
    Jan 2011
    Default BMW MULF repair
    I have 8 units of BMW MULF modules, most of them year 2004.
    Problem is in damaged solderings of BGA and after it - bad software.
    Product codes with 6946393, 6953044, 6938943, 9123290, 9116725.
    There's Motorola CPU XC540203CZT75, Mask 2J13D.
    I know there's most of time hardware problem, can solved by resoldering BGA's. But software is also damaged.
    My question is, is there any possibility to read/write thru BDM CPU and external flash 28F128J3C150?
    Has anyone done this and what software/hardware used?
    I tried to flash via WinKFP, no success, product code corrupt or rebooting all the time.
    If BDM connection does not help, is there anybody who has working unit, BGA64 reading possibility and will make me a good working dump for 28F128J3C150 flash(i can read/write flashi with Beeprog2) Or maybe even has it already?
    Any help would be great!
  2. The Following User Says Thank You to juht For This Useful Post:
    depanatorul (31st August, 2017)
  3. #2
    Mar 2010
    99,9% the damage of the content flash 28F128J3C. Only soldering never helps. Checked on a dozen or so pieces.
    I enclose the file with the new program. Will heal every MULF. Beeprog in this will help.
    I think, that I helped.
  4. The Following 20 Users Say Thank You to markmich For This Useful Post:
    amor89 (23rd December, 2017), asliyucegsm (2nd September, 2023), Col19 (16th January, 2020), darka7 (11th September, 2017), depanatorul (31st August, 2017), DOUGLASDL (17th September, 2017), elephantul (6th January, 2017), eLKa (8th February, 2019), elmaro (17th November, 2018), h0ly (13th September, 2017), kaleval (21st December, 2018), line44 (27th February, 2021), mer6 (20th March, 2018), MOBILTRONIC (18th January, 2020), moserts (15th January, 2020), Raptor181 (12th January, 2018), riker82 (13th May, 2019), Sazeck (4th February, 2020), sbalazs22 (11th September, 2017), sebastian (26th August, 2018)
  5. #3
    Aug 2016
    Hi every one i have a mulf2 usb unit that turns on and the fiber optic has light coming out , but i cant read aif and i did try to flash with Winkpf or with Expert mode, no luck! any one any idea? i have xprog will that help me in any way to restore it? i need dumps to, but not for mulf1 - i need it for mulf2 high usb. thanks
  6. #4
    Aug 2016
    hmm=? pls help
  7. #5
    Apr 2017
    Dublin, Ireland
    Quote Originally Posted by juht View Post
    Did you have any luck with repairing this, i'd love to give it a go on mine if it worked for you
    (sorry for digging up an old Thread)
  8. #6
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi mates! Is there any way for read 28F128J3C on board without BGA?
    Thanks in advance
  9. #7
    Jun 2017
    france
    Hello
    I also have problems with the module mulf,
    But just sound cuts when it's hot in summer,
    Do you think there may also be a programming problem or a bga hs solder?
    Thank you
  10. #8
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Hmm someone must know the work around on these units
  11. #9
    Jul 2010
    Bucharest Romania
    Hello friend
    What type of programmer do you use to read and write 28F128J3C chip ?
    Thank you !
    Quote Originally Posted by markmich View Post
  12. #10
    Jun 2017
    Hello
    ChipProg-48 or Beeprog2.
  13. #11
    Jan 2011
    I test this file, but i dont know 100% how to write that file with Beeprog2, i have adapter but there's too much settings to pick. I test and will post result, still no success
  14. #12
    Nov 2017
    Default hello
    My navi frozen when I connect mulf at the car. What do you say? IT same probleme like you?
  15. #13
    Jun 2010
    So the flash is always needed to desolder or is there jtag pins somewhere?
  16. #14
    Jun 2010
    Anything new on these?
  17. #15
    Oct 2017
    Hungary, Budapest
    Hi, I can't download this rar Someone can send it to me? Interested in repair of MULFs
