Results 1 to 11 of 11
    gpmoto2's Avatar
    Sep 2011
    Default crash nissan NV200
    Hey friends please clear Airbag Nissan NV200
    285563LS1E
    eeprom 93C56
    Thank you for your help!
    kiriki6969's Avatar
    Madrid
    Test and report friend..........
  3. The Following User Says Thank You to kiriki6969 For This Useful Post:
    gpmoto2 (27th October, 2016)
    UK
    Smile Clear
    Clear attached.
  5. The Following User Says Thank You to smc14c For This Useful Post:
  6. #4
    eeddyy23's Avatar
    long beach ca
    first will no work just clear ffs after a55a dont erase a55a it will work
    A question that sometimes drives me hazy: am I or are the others crazy?
  7. The Following User Says Thank You to eeddyy23 For This Useful Post:
  8. #5
    Apr 2016
    Hi guys, i've tryed to clear mine, but when i programed it, the unit was not recognized,
    Somebody can watch my files?
    Thanks in advance
    Nissan_NV200_285563LS1_crashed_and_cleared.rar
  9. #6
    FxShaw's Avatar
    Nov 2013
    Outta This World
    File is all messed up that is why.
  10. #7
    Apr 2016
    Default why do you say that?
    Quote Originally Posted by FxShaw View Post
    This is the only change that i've made, why do you say that the file is messed up?
  11. #8
    credoline's Avatar
    Србија
    Because file is messed up from beginning. You are make problem with file. Too little knowledge you have.
  12. #9
    Apr 2016
    Hi, seems that problem was the original read was corrupted, i tryed to write back (Crashed file) and the unit its still not recognized.
    I cleared the original file of GPMOTO2, and the unit is recognized with 0 DTCs, but the dash lamp its still on.
    Somebody have a virgin or clear file for this unit?
  13. #10
    credoline's Avatar
    Србија
    Good file or virgin will not help you. You are still make mistake, the same mistake as from beginning. Original file has NOT be corrupted !!! You are make file to be corrupted, understand ?
  14. #11
    Apr 2016
    Default Really I don't understand, I've two units, with different reference, 28556JX00E (2
    Quote Originally Posted by credoline View Post
    Really I don't understand, I've two units, with different reference, 28556JX00E (with two front airbags) and 285563LS1E (only one front airbag).
    I readed both with carprog, when i rewrited the same bin file that i've readed, without making any change only the 285563LS1E is not recognized, and I think that the problem was bad reading / bad contact with the dip clip adapter.
    I writed the file in the first post to 285563LS1E and the unit is now recognized, and later I erased the crash (i'm beginner, but i've erased other units) and the unit don't show any error and it's recognized, but the light still on in the dash,
    i'm asking for the file because i'm not sure if there is any problem with the file or it's incorrect erased.
    PD:If really it's messed up, i don't know why, because i readed both with the same tool, carprog. and one it's ok and other no.
    Thanks!
