Results 1 to 15 of 20
    DK Veteran prosec's Avatar
    turkey/istanbul
    Default nissan qashqai 98820 4eh0c i need clear file
    98820 4eh0c
    627260200
    xc2336b-40f
    i need clear file
    b.r
    turkey/istanbul
    any idea ?
    ...where was Columbus
    Default 98820 4EH0C clear
    This worked for me, I used CPT tool for it.
    Try then report
    Pass in PM
  4. The Following User Says Thank You to Air For This Useful Post:
    prosec (29th October, 2016)
    PT
    CPT tool not support that version, got dumps for some 4EHOC and for 4EHOB and ther some differences.
    Clear from them is not a clear.... but kind of copy paste from other dump. carefull...
    Solution from codecard online also pastes new data inside part of bin.
    Quote Originally Posted by carteknik View Post
    CPT tool not support that version, got dumps for some 4EHOC and for 4EHOB and ther some differences. Clear from them is not a clear.... but kind of copy paste from other dump. carefull... Solution from codecard online also pastes new data inside part of bin.
    I've tested many with same P/N modules with no crash inside they have HUGE differences. I did as I told you at least 5-6 modules with CPT tool successfully
    Top Poster kristikapa's Avatar
    Anyone can help me clear this file?
    98820 4EH0C
    Thanks.
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Quote Originally Posted by kristikapa View Post
    98820 4EH0C
    Thanks.
    Your cleared file, report back, clear errors, switch ignition off for 10 sec, switch ignition on, clear errors again and done. Pass in pm.
    Best regards.
    Dragon
  9. The Following User Says Thank You to dragon100 For This Useful Post:
    kristikapa (16th July, 2017)
  10. #8
    I will test on Monday and report. Thanks.
    EDIT: Tested and it worked
    Sent from my ONEPLUS A3003 using Tapatalk
  11. #9
    Sep 2015
    Default NISSAN
    Hello friends, someone please help me with this box of nissan qashqai thanks for your help
  12. #10
    Sep 2015
    Default NISSAN
  13. #11
    dragon100's Avatar
    Jan 2012
    Numbers the same like in the tread ?
    Best regards.
    Dragon
  14. #12
    Sep 2015
    Yes sir, he left the post 2 times
    sorry
  15. #13
    dragon100's Avatar
    Jan 2012
    Quote Originally Posted by andresvargas704 View Post
    sorry
    Your cleared file, clear errors, switch ignition off for 10 sec, switch ignition on , clear errors again and done.
    Best regards.
    Dragon
  16. The Following User Says Thank You to dragon100 For This Useful Post:
    andresvargas704 (31st July, 2017)
  17. #14
    Sep 2015
    Hello friend thank you very much works 100%
  18. #15
    paradise on world
