Try and report. Change bad elements or join resistors 2-3 ohm for check and clear errors.
Best regards.
Dragon
spast (28th October, 2016)
Not work, same DTC- "B1698 Collision decision (hi volt cut)"
Vehicle won't move :-(
Try this, should work.
Best regards.
Dragon
Not work :-( . Now DTC is Internall Rom/Ram error)
I don't know what is this
Best regards.
Dragon
try and report
tested
100% this file should work......
clear dtc after write this file vehicle should start
Thanks ,but how about password :-) ?
You know mate without reset SRS ecu you can start vehicle
Disconnect srs ecu and Clear dtc in HV system then you can start vehicle...
I have done it my self
Also your file is clear now
Sent from my C5502 using Tapatalk
spast (29th October, 2016)
If you have dump file send me it. Becouse VIN number inside Srs dump file. This file can't use to another vehicle
If use this file to another vehicle, you should program vehicle vin number or should edit clear file again with your vehicle VIN number
