Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    luis12's Avatar
    Jan 2011
    Panama
    Default Toyota 4 runner 2015 Steering angle
    Need to unlock a Steering angle sensor Panasonic 89245-30110 it has 24cs02a it has internal error and is stuck in -834deg, tryed dump from good sensor and now it reads until 45deg and gets error, think need to virginize dump in order to self align magnets inside, I tryed a lot of positions of magnets but hard to set to 0 deg, has anyone method to virgin dump and recover sensor, thanks.
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by luis12 View Post
    Post your dump file I can check it
    Sent from my C5502 using Tapatalk
  3. The Following User Says Thank You to Brayn For This Useful Post:
    LooserX (9th May, 2017)
    luis12's Avatar
    Jan 2011
    Panama
    Hello friend, this is orig dump with error...
  5. The Following User Says Thank You to luis12 For This Useful Post:
    br.balazs (25th February, 2017)
  6. #4
    Brayn's Avatar
    Oct 2015
    Colombo
    here you go
    try and report please
    DTC should goes off
    after Test mode run for 1 minuets
  7. The Following 7 Users Say Thank You to Brayn For This Useful Post:
    br.balazs (25th February, 2017), Dotcom2509 (5th December, 2018), Javed11 (12th June, 2017), LooserX (9th May, 2017), luis12 (1st November, 2016), pcofre (1st October, 2019), ZIOMAL4340 (4th October, 2017)
  8. #5
    luis12's Avatar
    Jan 2011
    Panama
    No luck friend, error appears in 20degrees or more, I test with a good sensor dump and same issue, tryed good board on bad sensor body (magnets assembly) Works OK, so magnets dont are problema, think that need a virgin dump to try recover it or perhaps micro has part of culprit, any one has solved this ?? I see Iprog has solution. Thanks any help.
  9. #6
    Brayn's Avatar
    Oct 2015
    Colombo
    After write my files what happen??
    Write my files turn on ignition then check what dtc have
    Clear dtc and check all dtc gone if yes
    Go to Abs system and utility Test mode run. Also check how about degree have
    It should be 0 when steering wheel ahead
  10. The Following 5 Users Say Thank You to Brayn For This Useful Post:
    cougar89 (23rd April, 2018), LooserX (9th May, 2017), luis12 (2nd November, 2016), rtbdiagnostic (12th January, 2020), vanos batam (2nd February, 2022)
  11. #7
    luis12's Avatar
    Jan 2011
    Panama
    Ok the blockage gones, now I center sensor and conect then read is about 0 degrees so when moves to any direction counter or clockwise at about 10 deg it takes error telling internal error and again turn on warn light, tryed with good sensor and put good file to bad sensor and same result, question you can interchange a good dump from good sensor to any bad sensor ? or it has any sincro. Thanks for your help friend.
  12. #8
    luis12's Avatar
    Jan 2011
    Panama
    SOLVED... thanks to BRAYN for made a reset wich used to find the problem and make scrypt for solution of futures modules.
  13. The Following User Says Thank You to luis12 For This Useful Post:
  14. #9
    Canada
    could you share the solution please is the chip in angle sensor,, I am having same issue with 2013 lexus RX350 stuck at 842 degrees
    thanx
    If i helped you please press thanx
  15. The Following User Says Thank You to janushaan For This Useful Post:
    Javed11 (10th May, 2017)
  16. #10
    Mar 2017
    Russia, Ural
    Everyone who is doing this again: 1. don't move the magnets never. 2. Use only the native dump
    I have the solution for 89245-74010, 89245-74020, 89245-30110
  17. #11
    May 2017
    Default 4runner 2016
    Quote Originally Posted by SoftDump View Post
    hi,
    i have a toyota 4runner 2016 and i have c1433 code, i already scan with easydiag x431 and try to reset but i have the slip light on and the steering symbol light on too, i can repair my sensor? when i scan the angle says -864 deg
    thanks a lot
  18. #12
    luis12's Avatar
    Jan 2011
    Panama
    Friend this problem sets when you detach Sir coil and turn Wheel more than 2 1/2 turn to any direction, maxium permit is 2 turns from center, if exeeds the known +854 or -854 sets. Only way to recover is cleaning error from eprom
  19. The Following User Says Thank You to luis12 For This Useful Post:
    rtbdiagnostic (14th August, 2019)
  20. #13
    Member chong5195's Avatar
    Nov 2016
    Default i has lexus same problem with this angle.. can share the dump pls ..
    pls share me l the dump for steering angel. 89245-30110 pls help ,, can send my email.. *Removed Email Adress...
  21. #14
    Oct 2017
    I have 89245-74010 plz help me to reset
    Sent from my SM-J700F using Tapatalk
  22. #15
    Dec 2017
    Default help me
    Quote Originally Posted by Brayn View Post
    here you go
    DTC should goes off
    pls pass, thank you
