before trying to mod file, have tried to check / change preheating module? maybe reason why yours glowplugs brun....
Hello, I need to renault laguna 2 2.0 dCi change the spark plugs of 11 to 7 volt, maybe someone knows what needs to change in the file, not to get burned.
nr.ecu 0 281 012 199 sw.1037377545. ORI.rar
Exactly... 7V plugs have much lower resistance so even short 12V pulse of heating will burn power stage in module... This isn't softqare, but hardware issue, i think
I have a mechanic friend who has exactly the same problem. He put new plugs in. Didn't realise they are only 7v and burned them out in 2 days. Renault said they can program the voltage change for ?65 so it can't be that big a job. Does anyone know which equipment will do this? if it is cheap enough I will buy it myself.
OFF TOPIC:-
Jeep and Scum of the Earth (TM) same silly idea, they just
sell "standard" glow relay & 12 volt plugs.
sounds odd, why not just put 12volt plugs instead?
walk rounds parts place
I am not sure you already solved it, but you have to change on the Renault Clip the heating mode from Slow (the standard one on that engine - black ring glow plugs) to Fast - white ring.
Without that, 2 months and the glow plug will be burned.
On the clip, after diagnosing, injection module, there is Repair top menu where you can reprogram some things, and glow plugs are there too.
No need to modify ecu.
Thanks Luke. Just ordered Renault Com which I've been assured is as good as clip so will try when it arrives.
You need to change settings with clip if already settings exist. Some older version of the firmware of ecu did not have that possibility yet ... so you have to update ecu firmware first.
br
Anyone know how update ECU firmware if I need to??
Use renault CAN Clip interface with reprog DVD.
PierreTheron (2nd February, 2017)
Anyone know where I get DVD?
Update!! Bought CAN Clip and Reprog. Option to change glow plugs didn't appear so had to update ECU. Some **** unplugged power supply while programming ECU with Can Clip/Re-Prog so Can Clip stopped programming. Now I've got no Communication with Injection ECU. Any ideas anyone??
what ecu is in it ? edc16 or sid ? both can read by bdm read and you can add original file , did you save any ecu info like software and hardware numbers
EDC16C36. Saved flash backup with kess first but can't detect ECU to write back. Kess and CAN Clip can't detect VIN in ECU now via OBD. I've read the ECU EEProm 95320 direct and the VIN is clearly visible but I've tried reading flash via BDM with KTag and Galletto v54 and can't communicate. I've never done BDM before so not sure I'm doing it correctly but I followed instructions. I've come to 2 conclusions.
Either EEProm is stuck in program mode (that's where vin is) or ECU is spiked and dead.
