Results 1 to 7 of 7
    Jan 2016
    Default A4, A5, A6 smartkeys
    Hi Guy's.
    Do you know if these keys coming ofcourse from Chineese supplier are interchangable ??
    I've done few A4 8K so far but my supplier told me that his keys are universal
    My keys are 868Mhz.
    AUDI A4 / S4 2009
    Original key with PCF7945AC HitagExt transponder, precoded by Component Security
    ( 8T0 959 754 K, 8T0 959 754 AG, 8T0959754S, 8T0959754M and others )
    AUDI A5 / S5 2008
    ( 8T0959754A, 8T0959754H, 8T0959754P, 8T0 959 754 C - and others )
    AUDI A6 / S6
    ( C7 - 4G ) 2011
    Original key with PCF7945AC HitagExt transponder precoded by Component Security
    SmartKeys 4G0959754K, 4G0959754G, 4G0 959 754 - and others
    Apr 2011
    in lebanon
    Hi Guy's.
    My keys are 868Mhz.
    Hello.
    about universal, yes it can done to adapt all kind part number on a5 a4 q5 ....even what number is it or even the keys are from china, but the different in the remote control is the frequency 433mhz and 315mhz or 868mhz dose not accept to work lock unlock central locking system or if the car is keylees go,must be same frequency. 2 times my customer give it to me chines remote it done with me. but the others all i work on original remote control.
  3. The Following User Says Thank You to haroutioun For This Useful Post:
    amigokola (14th November, 2016)
    Chinese keys some models not start car, write " safe" on dash.
    original keys can be 315, 868, 433 mhz and keyless not keysless, all work good
    Jan 2016
    I've tested these keys and all work great but I didnt use them on A5,Q5 and dont know if they fit to new A6. I know that freequency has to be the same.
    Quote Originally Posted by reks13 View Post
    Jan 2016
    So when freequency match there should be to problem with remote (A4,A5,Q5,A6) as transponders are all the same PCF7945AC HitagExt ??
    Quote Originally Posted by haroutioun View Post
    Hi Guy's.
    My keys are 868Mhz.
    Hello.
    Apr 2011
    in lebanon
    Quote Originally Posted by amigokola View Post
    Hello.
    first you must know what kind the remote frequency 315mhz or 433mhz or 868 mhz, when you be sure what kind freq, so after it accept to program starting system to bcm,after programming the key automatically it work lock unlock system. yes a4 a5 q5 those all are same transponder which can accept to adapt.
  8. The Following User Says Thank You to haroutioun For This Useful Post:
  9. #7
    HeXeN's Avatar
    Mar 2015
    Can dealer adapt virginised used smartkey straight away or need to be precoded to car first?
    edit: ok I found answer, it need to be precoded. Dealer cant adapt used virginised key very annoying for audi keyless owners especcially cars 2015+
