Results 1 to 15 of 17
    Apr 2014
    Default VW golf 4 Marelli IAW 4MV need fuel map location
    Hello everyone I need help with the search for fuel map in Marelli IAW 4MV
    I join Ori + Kp but warning map call ''injection'' in kp 12x24 wrong i think is throttle body control. (Name by ECM titashit) i try mod this map the car goes wrong
    iddle rev 1500 rpm
    Ignition map good.
    I need to pass this car to E85 fuel.
    Thank's
    Act Tuning's Avatar
    Sep 2016
    Around
    Injection map - 057000 12x24
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
  3. The Following 2 Users Say Thank You to Act Tuning For This Useful Post:
    kinketotua (10th October, 2018), romano21 (15th November, 2016)
    Apr 2014
    Thank's ACT But i think's it's wrong i try mod 12X24 AT 0x57036 i add 35% Fuel at all map for E85 but car go wrong bad idle rev 1500 rpm and car alternative stop and ESP go off
    I think's this map it's for throttle. Not fuel map ...
    Act Tuning's Avatar
    Sep 2016
    Around
    This is correct map for injection it not a guss, so i dont know what you try to do or how, or what the problem with the car, so you can count on it that is injection map ,
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
    Apr 2014
    ok i understand Act Thank's !
    Apr 2014
    with help of ACT Tuning 2 lambda map
    058AB2 12X24
    058CF2 12X24
    Thank's ACT
    Apr 2014
    2 lambda map
    058AB2 12X24
    058CF2 12X24
    057036 12X24 it's injection map
    05BA98 12x20 IGNITION partial load
    05BCA8 19x4 IGNITION full load
    If you have another map post it
    May 2016
    Russia
    Quote Originally Posted by romano21 View Post
    What this map shows? If Air-Fuel Ratio ... but AFR-map does not look like this. May be amount of fuel injected (mm3/str)?
  10. #9
    Sep 2018
    Hi Guys,
    I introduced myself before and so am still new on this forum. Today a Seat Ibiza 1.4 16V of my friend is here. I noticed his car have a Magneti Marelli IAW4MV ECU. I would like to do some mild chiptuning on his car (ignition advance, maybe Pop&Bang). However, this protocol and type of ECU is new for me.
    I read out the software with my Galletto V54 and opened it in WinOls. However, where do I have to start? Could anyone help me with the fuel and ignition maps? Is there maybe a damos available? Unfortunately, I could not download your files above (maybe because my account is new) which I think that helps me.
    Car and ECU info:
    Seat Ibiza 1.4 16V - 2006
    036906034DG
  11. #10
    Jan 2016
    Post ori - those 4MW ECUs seem to have more or less the same map locations. But I dont think there is any powergain... Maybe some ign when running better fuel. Or lambda to 0.88 to increase power in low end torque...
    regards
  12. #11
    May 2017
    Hi Guys! I am a new!
    Ι want to ask the following for my ecu Magneti Marelli iaw4mv
    036906034DG.
    When i open the " fuel map or ignition map " with WinOls the numbers i see, some modification are need to see the real fuel level or ignition???
    If somebody can help me please.
    Thank you!
  13. #12
    Sep 2018
    Thanks for your response!
    I agree with you but that doesn't matter. Only for fun and would be nice if we gain a little bit with ignition advance and fuel enrichment.
  14. #13
    May 2017
  15. #14
    May 2017
    No one??🤔🤔
  16. #15
    May 2017
    Guys...!!! Help me!!!
    Map table for this
    036906034DG RF 4MV 5953 iaw4mv marelli???
