Does anyone have a damos compatible with my file?
Thank you !
This vehicle, which is carburizing at E85, is experiencing progressive difficulties in cold starting, as the temperature drops below 20 degrees C.
Could you help me to find where are the cranking injection values, based on temperature?
Thank you !
Renault Espace 2004 2.0T 163CV
ECU : Sagem S2000RPMT
HW : 8200279458
SW : 8200352155
Update : 8200311869
Renault Espace 2004 2.0T 163CV Sagem S2000RPMT HW8200279458 SW200352155 MAJ8200311869 ORI.rar
Thank you !
There are two address C0FB , C10C - 17x1 factor 16 = RPM. Temp waher from -40 to 120 C , step 10deg.
kitnoos2002 (2nd December, 2016)
Thank you very much but I'm looking for Fuel Injection VS Temperature during start.
I think you gave me Idle RPM VS Temperature.
You don't have any options with this worse ECU. Just increase idle at low temperatures. Here revolutions are the result of the amount of fuel injected.
I found a damos ("2A4200.A2L") for a very close ECU (S2000 Renault Espace).
This damos don't work with my software ID !
But if I open the good file compatible with this damos, I can see that the values are like it :
(Cooling temperature dependant table for Fuel Injection Mass during start)
I think I found what you're looking for. Address AA5B 17x1 , faktor 0,064 (ms). Excise temperatur C from -40 to 120 C , step 10 deg
kitnoos2002 (5th December, 2016)
Thank you for your informations !
I will try, but you found at address 0xAA5B : Ctp_tco_dec_sta_ti.
I'm not sure but I think "dec" is Fuel decrementation just after start :
Maybe I'm wrong but I think the curve must be like this :
OR
With your informations, I could see just below, at address 0xAA7E (17x1), there is a curve that looks like cranking fuel correction factor :
But without compatible damos, I can not be certain that this is the curve I'm looking for.
What do you think ?
Did you find damos file ?
Which software did you use to upload ecu file ?
I found method with galleto and boot method.
I search easier solution.
Aymeric
I use also Galletto v54 . Not damos , not easear solution for flashing.
