Mobo swap.
Results 1 to 5 of 5
Thread: Mobo swap.
    DK Veteran AirShowNut's Avatar
    Jun 2008
    Somewhere - UK.
    Default Mobo swap.
    Hi all.
    I am thinking of swapping the motherboard and processor in my desktop running genuine windows 7 home premium.
    My question is as follows.
    If i go ahead and do the upgrade will my copy of win 7 still run ok without the need for re-activation and all the hassle that goes with it or will it simply run as normal.
    In the past i have had major issues after a similar mobo upgrade and it took me 2 weeks to get M soft to issue another license key to me.
    I intend to put the new mobo in the case that i currently use so all hardware will be the same as it was apart from the mobo.
    Any info gratefully received.
    Cheers.
    Apr 2008
    I changed a MOBO using the win 7 OEM key , and it was okay. People are selling old win7 keys from scrap comuters. I thought it was Win 8 and 10 that the key is locked to the motherboard.
  3. The Following User Says Thank You to alec For This Useful Post:
    AirShowNut (22nd November, 2016)
    Jun 2008
    Somewhere - UK.
    I had problems with win 7 the last time i upgraded my mobo.
    After a LOT of hassle with M soft they agreed to give me a new key and conceded that pc's and components have a finite life (i also told then i would get a pirate copy ).
    They also said they would look into not having the o/s locked to the mobo (or main board as they called it) and would probably do something about it in a future update.
    As you have upgraded then M soft may have actually been true to their word (unusual).
    If it went ok for you then i may go ahead and upgrade my mobo,i did think of a new pc but i refuse to have win 10 spying on me all the time it's running.
    Cheers for the message.
    Jul 2013
    Latvia
    I know that MS usally are not happy when You are changing mobo and then using your old key. At least at job - when some mobo dies we are buying new license.
    Jun 2008
    Somewhere - UK.
    I decided to buy a new pc instead of a mobo swap so all should be ok as it came with win 7.
    Cheers all.
