just4upal (24th November, 2016)
Try it. I didn't apply, but can will work.
antlio (24th November, 2016), Chongcheeluan (8th March, 2018), cmassou (1st December, 2021), dadal (22nd September, 2017), epd1221 (23rd November, 2016), just4upal (24th November, 2016), pedritosola (20th July, 2018), romecu (10th January, 2017)
Ill try today and report thanks amigo
fcarocha (18th March, 2023)
tested work 100% thanks amigo
hi can someone help me with a immo off file please
siemens vdo
S122237006 B
1214-7557395-01
S83293
flash -29f400bb
thanks in advance
Checksum needs to be corrected or used a flesher for record a flash.hi can someone help me with a immo off file please
siemens vdo
S122237006 B
1214-7557395-01
S83293
flash -29f400bb
thanks in advance
cmassou (1st December, 2021), dadal (30th September, 2017), driiven (21st March, 2019), kander2000 (20th June, 2023), trevormaharaj (11th January, 2017)
hi can you perhaps tell me what software to use to correct the checksum
thanks again
Hi jai need this file off thanks S122237006B
Siemens ecu immo off
Hi Friend
I have same ecu and same car.. did you chekcum corrected and cut any wire or disconnect EWS module after flashing immo off file ??? I read it on ither topic that when you read flash by OBD socket or in bootmode then change the file siemens encoding, and you must remove that modification. before you write it back to flash.. is it rignt ? did you read/write by OBD or desolder 29f400 ??
Problem is solved ( thanks to minor )
hi mate i has same ecu need immo off can share password
minor can help me off this dump .. s122237006b 29f400bb
here immo off , it does work 100%
rep+thanks+pm= pass
bugarcek (5th April, 2018), bursuc (26th September, 2020), CHIKO (25th May, 2022), chong5195 (9th March, 2018), Chongcheeluan (9th March, 2018), driiven (21st March, 2019), fcarocha (28th February, 2023), kingarthas (19th March, 2018), rabsanek (30th January, 2022), scoot (22nd August, 2019), ykizak (10th December, 2018)
thank mate .. share password pls
