Page 3 of 41 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 607
  1. #31
    Quote Originally Posted by aprd68 View Post
    why do you wat to remove the filter @
    To avoid extra maintenance costs...
  2. #32
    Smile 307 fap
    the filter is there for a purpose ie cleaner & greener , the vehicle might not pass the smoke emissions when it is in for its mot, my pollution warning came on in the car this then puts the engine management light on ,eventually the car will go into LIMP mode ie no power, i priced the additive from my local peugeot dealer and it was ?94.00 + vat, you got 4 lts fluid & a filling resevoir so i went to my local car accessory store & bought 20 lts adblue (?14.00) which goes into commercials, i made up a filler as the fluid is gravity fed into the resevoir, filled the res, on to the motorway 50 mph 3rd gear & the filter regenerated itself, took it to a garage , they lobbed it on the computer & they told me it didnt need regenerating, already done, you will need a pit or a ramp to fill the res as it is mounted underneath the car @ the rear passenger area, took me about 1 hr max once i worked out what to do, if anyone needs anymore info then get in touch
  3. #33
    Hi friends,
    now is possible to disable FAP or DPF in a lot of cars...only look this link:
    Available modules
    Only need to have good tools to read-write ECU sw.
  4. #34
    May 2009
    Quote Originally Posted by rocris View Post
    Hi friends,
    Available modules
    Anybode use ths soft??
  5. #35
    Quote Originally Posted by MasterMaster View Post
    I know someone using this soft. I heard also crack is available.
    So I'm very interested in a crack. if you can offer please PM.
    Thanks.
    Put original sw here or send by PM...will work to crack it
  6. #36
    Default ANTI POLLUTION FAULT
    if your peugeot comes up with this fault or diesel addative min level or particle filter blocked as i did with my 807 2.2 hdi i have found a bloke who will deactivate all the anti pollution gubbins and map to give loads ov torque.he has just done mine today after 3 months of limp mode trying all sorts of things to sort it Ecuflash - Engine Tuning - Ecu Remapping - Chip Tuning - Doncaster South Yorkshire follow this link and ring andy never again will you have problems .
  7. #37
    branco's Avatar
    paris france
    Quote Originally Posted by steich View Post
    Hello. If you are able to read your ECU ( EDC15, EDC16, EDC17, Siemens SID ) and send me the file, post it here and i will sort it for you for free
    EDITED BY ADMIN
    here file from peugeot 607 2.2 hdi
    can you remove FAP please?
  8. #38
    branco's Avatar
    paris france
    here demo version for ecu safe
    maybe can somebody crack it
    enforcer software don't work
    regards
  9. #39
    oh jee...
    ... & bought 20 lts adblue (?14.00) which goes into commercials, i made up a filler ...
    AdBlue is = NH3. This is something completely different than the additive used in PSAs FAP to lower the temperature at wich the particles can be burned of...
    ...good luck
    K
  10. #40
    Quote Originally Posted by citronel View Post
    I sent you PM with details from where I bayed my interface.
    what micro are you use ?
    atmel or pic ?
    Can you tell me also the information from were you buy your interface.tanks
  11. #41
    KILL_THE_IMMO's Avatar
    spain
    thank u my friend
  12. #42
    many thanks for Your great deal
    possible for MM6F too? /fiat multijet/
    PeterOBD
  13. #43
    hi steich,
    i have a peugeot 307 2.0hdi with fap and adblue addition... you can remove fap in software?
    i attached original file.
  14. #44
    Suppose I want to flash my Peugeot 2.2 HDI 15C ecu with a file that removes all the Fab stuff, but it fails and I can't start the engine again. How can I recover the ecu again?
  15. #45
    hi, you always read your ecu and make a back-up first, so you always have it to re-flash if any problems, i`m interested in this post because i have this problem at present, it`s a pain thx paulyd2k
