Page 41 of 41 FirstFirst ... 31363738394041
Results 601 to 607 of 607
  1. #601
    Dec 2015
    Hi everyone, I used to dpf off EDC16C34 using the switch but I encounter a matter with a peugeot 3008 from 2 day, it throw me P1446 DTC and I'm not able to erase it. Can somebody shut this DTC off of my file? Best Regards. AngelPowy
    I give you ori file.carto ori (1).rar
  2. #602
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Check this and turn off fap again no cs.
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  3. #603
    Quote Originally Posted by drewdom View Post
    Hi.Here fap off:
    I programmed the ecu with your file but the 04008 error come back after few kilometer. Need cut any wire?
    Please help!
  4. #604
    drewdom's Avatar
    Aug 2010
    What about P1446?Do You turn of the fap switch again?And what is definition of this 04008???
    Send by Meizu M2 using tapatalk
  5. #605
    Oct 2015
    For P1446 you try just reset fap parametars.. go to ECU, set up new fap and new bag for aditiv, same do in pump for aditiviation.. You can check to in parametars
    ECU>Parametars standard>FAP Info , find aditiv level value... Full tank is ~ 2100ml, empty is <100ml . .
  6. #606
    Feb 2013
    Belarus
    Default edc16cp39 Peugeot 4007 2,2 fap+egr off needed
    Hi to everyone. can anybody help me with this file? I need FAP and EGR off disconnected, and p0123 and p2100 faults deleted. Thanks in advance. 1037391747.rar
    solved.
  7. #607
    acam712's Avatar
    Mar 2016
    in the middle of the bulb
    Hello.
    I need dpf and add off in Peugeot 406 2.0hdi ecu 0281011080.
