Page 12 of 41 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 607
  1. #166
    Bulgaria ,Plovdiv 4000
    i have same problem with ecusafe,it don`t work on SID803 and can`t get support from then,i write several mails and nothing.Anyone make this successful on 307 136hp?
  2. #167
    Default I can help- you
    Quote Originally Posted by batpepi View Post
    ( no addys to be posted )
  3. #168
    Default C5 fap remove
    Quote Originally Posted by sidoski View Post
    HI
    CAN YOU REMOVE THE FAP PLEASE FOR THIS FILE
    Take this and test
  4. #169
    mail sent
    thanks advance
  5. #170
    Afghanistan
    Default help me for my 607 hdi
    help me for my 607 2.2 hdi fap to desable the fap the dump is
  6. #171
    Italy
    here is file no fap
  7. #172
    Quote Originally Posted by pawliukazz View Post
    Fap removed, Pass in PM...
    please pass to the file peugeot 407 fap off
  8. #173
    Hi. I need dpf remove. I modified with ECUsafe but now i have antipollution fault and esp asr not work. Before only additiv problem. This is Citroen C5 2002 2.0 HDI edc15. the original file attached. Thanks for help
  9. The Following User Says Thank You to jaca4591 For This Useful Post:
    hackero (16th October, 2020)
  10. #174
    Member Sigius's Avatar
    Nov 2010
    Is necessary to remove FAP filter from the car after modified file writing to ECU ?
    We have updated file with EcuSafe for Citroen C5 2.2 HDI edc15 and have got no rezults . Problem still persists. Still no power and engine lamp is still on.
  11. #175
    pawliukazz's Avatar
    Jupiter
    Quote Originally Posted by Sigius View Post
    you must remofe fap filter itself ftom the car...
  12. #176
    and reset the faultcodes.
  13. #177
    so to do DPF i need to remove fap filter itself(or drill couple big holes?),disconnect sensors,read ecu,write back modified file,reset fault codes....job done?
    i try to do 607 2.2 edc15 with out removing filter(leave sensors too) and after 30miles my problem back.
  14. #178
    Polotsk
    Hi. Please help with FAP
    C5 2.2 2001
    Thanks.
  15. #179
    Nov 2010
    help remove fap 307 hdi 2000/110cv ecu bosch ed15:
    file orig read galletto:
  16. #180
    pawliukazz's Avatar
    Jupiter
    Quote Originally Posted by exorcistaecu View Post
    Here's your file without fap
  17. The Following User Says Thank You to pawliukazz For This Useful Post:
