Yes, I did with my Peugeot 2.2 HDI EDC15 ecu and it works.
Ecu read with Galetto, file modified, and flashed back with Galetto. Removed the fap. Turbo comes in earlier and quicker and I drive 100 km. more with a tank. I'm happy with it.
what happend to this link
http://www.digital-kaos.co.uk/forums...-crack-121684/
i did no safe the file
I'm a newbie here and have a peugeot 406 2.2HDI Coupe 2003 that needs a FAP filter deactivation and I'm not allowed to add attachments to my posts. Can someone help me or tell me why this is?
Thanks,
Adam
After doing some reading I realised, thanks for the quick response though.
I have a Peugeot 406 2.2HDI Coupe 2003 (EDC15) needs a FAP filter deactivation can it be done please?
Thanks for the help.
Hi does anyone know the voltage from the pressure sensor back to the ecu i have checked the 3 wires and get a constant 4.65 volt from the orange wire, white must be earth and i get 0.6 volt from green wire to ecu with engine running, can anyone confirm that 0.6 volts sounds about right if this is correct i am thinking all i need to do is pull off the wiring plug and bridge the orange wire with a correct value resistor to the green wire to keep it at 0.6 volts for the ecu. Then i can remove the guts out of the fap with no errors being shown on computer, any advice sugestions appreciated.
thanks.
Hi buddies.
For months I am looking for information on this topic.
And I am beaten.
To this day, the most viable and reliable option would be to empty the filter and deceive the differential pressure sensor, putting a stop valve to shut off air pressure tube at the end of the filter.
This would always be in the normal range of differential pressure, and not regenerate.
I heard that this can now be done with software.
I have read that he had a friend who offered to do it. It does not?
Greetings.
Hi my friends!
Help me! Please help my car (C5/2,2 HDI/ EDC15c2) work without FAP filter.
Firmware file read from Galetto in attachments. Thanks.
