i need fap desactive for my 607 2.2 hdi the dump is
Thanks tuning.
I need to know is whether I can disable the ecusafe my fap.
I've got a mapping similar to mine, and tried the program.
But I have no certainty that it works.
For the moment, as I said, pour the fap and deceive the differential pressure sensor.
Citro, you can answer the question posed in my last post?
I have the ecusafe and not if that works. I only need the cable for the Galletto. Soon I will.
One question: If you disable the egr fap and then we can enter pp2000 same with you?
Thank you.
Thanks for your time citro.
The last question was:
if you disable the egr or fap electronically, there will be no problems entering the pp2000?
I mean, not been deprogrammed by plugging the pp2000.
Then the ecusafe work.
I am waiting to receive the cable for the Galletto.
Thanks again.
Elpit. I'm still in forocoches.
Citro has commented that with the ecusafe smoothly.
Galletto you used to read the map?
I have a question for Citro?n. Sorry to be heavy.
By revoking the FAP will also invalidate the additives?
hello albematty the fille is good but if you can give me this fille and augment the puissence ship tuning think you friend
You can make a Ecu backup with Galletto. You need it also to flash the modified(no fap) file.
hi guys can anyone de fap this file cheers in advance hopefullyk.rar
big thanks to woody file did the trick got a bit scary when first run aborted after 17% and for 20 mins it wouldnt load a thing finally put original map back in then after leaving ign on for about 15mins it made a pass straight through job done excellent thanx once again
