Page 1 of 34 12345611 ... LastLast
Results 1 to 15 of 607
Hybrid View
    Jun 2009
    UK
    Default Peugeot - Citroen FAP filter deactivation
    Hello all. Anybody met a problem, that could be solved by removing the annoying FAP filter from PSA cars?
    Below is all info I have, probably there are people who would like to share knowledge on this matter?
    In theory yes you can remove the FAP without any ECU reprogramming and also if required you will be able to restore back the FAP system:
    All you have to do is to trick the car system that the FAP it is working OK.
    This way you will solve problems like: Risk of FAP blocking, Aditive low... and save some money for this FAP system.
    3) tube from FAP injector to fuel tank need to be removed and need to be rerouted in to the FAP tank. This way the FAP injector will still work as it is supposed by car ECU and the EOLYS additive will never get low because it will be injected in the same tank of additive.
    2) FAP filter need to be removed or maybe just put a hole in old filter but the hard part come now:
    1) You will have to trick the differential pressure sensor to stay in the area of normal filter, this way the engine management will not send a request for regeneration and will work forever OK.
    "DIFFERENTIAL PRESSURE SENSOR
    The differential pressure sensor constantly measures the difference in pressure between the inlet and outlet of the
    catalytic converter/anti-particle filter assembly.
    This measurement makes it possible to determine the blockage level of the filter. The sensor consists of:
    - an electronic circuit for amplifying the signal,
    - a sensitive diaphragm.
    The diaphragm is subjected on one side to the catalytic converter inlet pressure (upstream) and on the other side to
    the filter oulet pressure (downstream).
    The sensor provides a voltage proportional to the differential pressure measured by the diaphragm (?P = upstream
    pressure - downstream pressure)."
    How you can do this, need to be study and check the value reported by the pressure sensor. Once we have that value it is almost done or maybe another idea it is to find the diameter of the hole needed to be driled in old FAP by experiments and math to match the pressure needed by differential pressure sensor to stay in the area of normal filter .
    edit:
    As I seen from diagram there are 3 wires to this sensor so it must be:
    3 - RED- VCC 5V or constant value.
    2 - White - GND
    1 - Orange - V from Sensor mesurement (~4.64v I have Risk of filter blocking....
    ( not is this order )
    all you have to do is to check that V from sensor and put a resistor from VCC to that wire.
    Resistor it is easy to calculate once we have the normal value from that pin.
    this is all, job done, no more FAP problems.
    DK Veteran cars's Avatar
    Aug 2009
    Italy
    There is only one small problem in the tank Cerina there 'is not a
    indicator for cerina level, so the ECU is a theoretical calculation based on the injection level in the tank.
    After a specific number of injections, the ECU thinks it has finished Cerina and turns on the MIL light, in this case, just reset the counters in the engine control unit or ECU FAP this happens every 80000 Km or 120000 Km depending on the model.
    PS:The latest PSA cars with FAP second generation have very few problems.
    Sorry for my English.
  3. The Following User Says Thank You to cars For This Useful Post:
    speedservice (27th October, 2021)
    Top Poster citronel's Avatar
    Jul 2009
    www.psaclub.ro
    nice... that theory was posted by me last year on eurovan2 forum when I bought my C5 1.6HDI FAP and had to solve the FAP problems...
    my problems was simple just: FAP washing + Eolys refill and additive computer reset and all was ok.
    To be sure that FAP will complete each regeneration properly I developed a device that signal regeneration phase on HDI engines so no more problems:
    Sensor Regeneration FAP & Turbo temperature
    In the meantime I study a different approach of FAP removal:
    if anybody with Lexia have access to PSA engines with no FAP: DV6, DW10, DW12 and can make a print of BSI & ECU configuration settings will be great to complete my study.
    thx
    Jan 2010
    Quote Originally Posted by citronel View Post
    thx
    Hello,
    Please describe the reset procedure for the additive computer with unknown reference in PP2000
    Thank you.
  6. #5
    Sep 2009
    hi,
    the bsi et ecu configuration are the same, just FAP present or not.
    to analyse the FAP data in ecu and BSI,it's more complicated.
    you can take xsara and c5 dw10 without FAP engine RHZ
    and 307 engine RHS, there the same ecu but one have FAP and the other have.
    there is a mux communication between engine ecu, additive ecu, i don't know how to remove it.
    for the moment i clean FAP and put 0 in ecu.
  7. #6
    Jul 2009
    www.psaclub.ro
    As I told, If you have access to PSA engines with or without FAP and Lexia please make a print of ECU & BSI configuration from DV6, DW10, DW12 and send me.
    I am on the right way to remove the FAP without simulate it.
    thx
  8. #7
    Jun 2009
    UK
    This sound interesting. You are doing the correct job I would say
    My best regards.
  9. #8
    Aug 2009
    Slovakia
    Default FAP
    I have experience with damaged FAP, so I?ve made fake "filter" to break exhaust gas. Because sensor of differential pressure check the difference before and after FAP. Original cerine I?ve changed to fuel. 20 000km and everything OK. No faults.
    My question is: How to disable FAP in engine ECU? In BSI I can switch to not present. I have multidiag...
  10. #9
    Apr 2010
    Default fap emulator
    Do you try to change all the eeprom 29f400 of an old 15c2 and put this to a a ecu with fap and configurate the bsi without fap what happen.
    Quote Originally Posted by fckju View Post
    hi,
  11. #10
    Jan 2010
    Default Peugeot 307 HDI
    Please remove the FAP filter?
    Peugeot 307 2.0 HDI FAP 0281011081
    thank you
  12. #11
    joubliss's Avatar
    Jan 2010
    Far away
    Quote Originally Posted by tibor8475 View Post
    thank you
    try this, and report
    Job
  13. #12
    Jul 2009
    www.psaclub.ro
    I discovered that some parameters in ECU settings refer to NO FAP system; this is why I want to compare few prints of ECU parameters configuration and ECU sw version.
    erikfrong what engine do you have ?
  14. #13
    Aug 2009
    Slovakia
    2.0 HDi 110PS year 2004
    when I set the FAP in BSI not present, car is running without MIL but in engine ecu are DTC?s. Additive pump etc... but engine ecu still compare pressure before and after FAP and this is the main problem. I think that is only one way use "tunned" software for ECU and turn off in BSI. Remove FAP and thats all
  15. #14
    Sep 2009
    Hi guys.
    I am very interested this theme.
    I have read with difficulty that you are working on the elimination of FAP.
    I have a 2.0 HDI 136cv.
    As with the Peugeot PPS, an option to tell FAP FAP YES or NO.
    One person I know has put into NO and nothing happens rarely.
    My question is:
    What if the PPS is disabled fap, we can empty it without danger to our error?
    Thank you.
    NOTE: sorry for English. I am Spanish and use a translator.
  16. #15
    Aug 2009
    Slovakia
    You can only disable fap only in BSI. I haven ?t found this option in engine ECU.
