Results 1 to 12 of 12
    yugo45's Avatar
    Default Mercedes ECU Renew
    Hi, I have ME2.8 ECU with eeprom 5p08c3.
    I renew Mercedes ECU bit want to make sure if it good, Car is far a way and do not want to go there to find out is not good.I attach both files.
    Also can someone tell me do I need to go Online with MB Star diagnostic or can do it offline?
    Thanks in advance.
    workshop
    offline programm with star
  3. The Following 5 Users Say Thank You to mercis For This Useful Post:
    capi (15th December, 2016), daxxer (3rd December, 2016), duplikeytor (15th March, 2017), Siham (10th March, 2017), yugo45 (3rd December, 2016)
    yugo45's Avatar
    Quote Originally Posted by mercis View Post
    This is solution form Ico's Software, I have this.But this clear all coding and everything.
    But do you think solution I post will work?
    I like to keep coding just to adopt drive authorization.
    vanos batam's Avatar
    Batam-Indonesia
    Offline will work..
    If problem post you eis dump..then ready start for you without coding etc..
  6. The Following 2 Users Say Thank You to vanos batam For This Useful Post:
    Siham (10th March, 2017), yugo45 (4th December, 2016)
    yugo45's Avatar
    Just to let everyone know, it worked good. Just went , and did drive authorization.
  8. The Following 3 Users Say Thank You to yugo45 For This Useful Post:
    gttuning (16th December, 2016), Siham (10th March, 2017), ttzag (15th December, 2016)
  9. #6
    Jul 2015
    kenya
    wat software du u use for renewal of ecu??wil appreciate
  10. #7
    Aug 2013
    Was this a crossfire or CLK?
    Was the car not starting?
  11. #8
    Feb 2015
    All ME2.8-->change first byte to FF--> virgin.
  12. #9
    yugo45's Avatar
    Quote Originally Posted by shanny254 View Post
    brain.exe....
  13. #10
    yugo45's Avatar
    Quote Originally Posted by duplikeytor View Post
    E class , original ECU missing, i had used ecu, and of course can will not start with used ecu.
  14. #11
    Aug 2013
    Quote Originally Posted by bawareca View Post
    Is
    this 100%?
  15. #12
    Aug 2016
