Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    no, i try to use Tag key tool of FVDI first time and i have erased some badly programmed PCF7935
    not try any used yet
    many thanks to friend kevfield
  2. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    doctore (13th June, 2017), mikajna (4th May, 2017)
  3. #17
    Dec 2008
    I know this is old thread but:
    No matter what I did with antenna, TAG Pro does not programm or erase PCF7935. Reading was and is after modification NO PROBLEM.
  4. #18
    Dec 2015
    Rafah, Palestine
    Quote Originally Posted by electronistul21 View Post
    you can see in this video options for keymaker.for 4D ,4C and 4E need use TIRIS
    out of the topic can any one tell me how to open my key tool maximized like tis video you can read the hole line
    i change the resolution many times but no success only like this
  5. #19
    t77's Avatar
    Poland Lodz
    Hello friends ...have a question ...How is value of resistor R12 marked yellow loop?
  6. #20
    t77's Avatar
    Poland Lodz
    Ok problem solved
  7. #21
    Oct 2010
    i dont know if mine worked fine before but nevertheless i installed 2x 271pf and tested blank id46 pcf7936 - it reads (1 of 2 new transponders, maybe dealer send me broken one)
    before rework, i could read megamos48 without problems
    EDIT: turns out the ones i received from the dealer dont work, bought from different guys on ebay and they do work fine!
  8. #22
    Junior Member MeMBraNe's Avatar
    Jun 2018
    Could anyone please be a bit more specific on the capacitor/capacitors used, eg tolerance and VDC
  9. #23
    Mar 2013
    RO Tarnaveni
    Thaks IT work with 680pf
  10. #24
    HeXeN's Avatar
    Mar 2015
    Mine completely not reading anything. Any solution for that?
  11. #25
    HeXeN's Avatar
    Mar 2015
    Tried to repair - not work - anybody buy new tag key tool from ali or fvdi ? Works ok? 40usd
  12. #26
    Jan 2013
    Quote Originally Posted by HeXeN View Post
    See if antenna has open circuit
    Sent from my SM-G781B using Tapatalk
  13. #27
    Jun 2015
    Quote Originally Posted by ohkarol View Post
    i think i found solution, after add 2x 330pF to antena reader i have precoded pcf7935 without problem
    see picture
    hello my friend can you help me is this capacitor
    331J
    KCK
