no, i try to use Tag key tool of FVDI first time and i have erased some badly programmed PCF7935
not try any used yet
many thanks to friend kevfield
I know this is old thread but:
No matter what I did with antenna, TAG Pro does not programm or erase PCF7935. Reading was and is after modification NO PROBLEM.
out of the topic can any one tell me how to open my key tool maximized like tis video you can read the hole line
i change the resolution many times but no success only like this
Hello friends ...have a question ...How is value of resistor R12 marked yellow loop?
Ok problem solved
i dont know if mine worked fine before but nevertheless i installed 2x 271pf and tested blank id46 pcf7936 - it reads (1 of 2 new transponders, maybe dealer send me broken one)
before rework, i could read megamos48 without problems
EDIT: turns out the ones i received from the dealer dont work, bought from different guys on ebay and they do work fine!
Could anyone please be a bit more specific on the capacitor/capacitors used, eg tolerance and VDC
Thaks IT work with 680pf
Mine completely not reading anything. Any solution for that?
Tried to repair - not work - anybody buy new tag key tool from ali or fvdi ? Works ok? 40usd
