Page 26 of 225 FirstFirst ... 1621222324252627282930313676126 ... LastLast
Results 376 to 390 of 3369
Thread: LONSDOR K518
  1. #376
    p1et's Avatar
    Oct 2013
    Somebody tested Volvo key programming? Interested fact is te calculation data has 'it's term of validty'. I mean if we calculate data from CEM Lonsdor accept calculated file but if we try it next day, then device say wrong file and we need to calculate one more time. I havent chance to test on real car yet, now just plyaing with CEM units. But I wonder how they calculate those datas and why they expire
  2. #377
    habbyb's Avatar
    Romania
    I did not have the opportunity to test on volvo cem or kvm , bat i can send e-mail to service lonsdor to ask , can you post here dump cem or kvm to test ?
  3. #378
    HeXeN's Avatar
    Mar 2015
    do you know if possible to buy with shipping from UK? anyone can give link to tested seller
  4. #379
    rob h's Avatar
    May 2011
    m.obdexpress.co.uk
    This is a good company.
    They ship from the UK.
  5. The Following User Says Thank You to rob h For This Useful Post:
    HeXeN (16th May, 2018)
  6. #380
    Jun 2016
    Quote Originally Posted by p1et View Post
    Yes, read the PDF, you can find on google.
  7. #381
    p1et's Avatar
    Oct 2013
    LMAO, perfect answer
  8. #382
    autochei's Avatar
    Mar 2013
    romania
    ssangyong rexton akl lonsdor delete key and then say voltage to low
    put voltage and some situation
    put x100 pro and finish the car succes
  9. The Following User Says Thank You to autochei For This Useful Post:
    HeXeN (25th May, 2018)
  10. #383
    Apr 2014
    Hualqui
    Today I have programmed a chevrolet cruze akl, read pincode type 1 well, but there is a bug in the function of programming keys, akl it says programming error after the counter of 10 minutes, it can be done in the function add keys, it works correctly but at end enters an infinite loop and never ends. Just unplug the machine and complete the procedure. This is when more than one key to be programmed.
  11. The Following 3 Users Say Thank You to perfido For This Useful Post:
    p1et (23rd May, 2018), rojhat (23rd May, 2018), servicekey (23rd May, 2018)
  12. #384
    Jun 2016
    If you use other key programmer to read out the data, then K518 need to transfer, and it will have 'it's term of validty'. If you directly use K518 + KPROG to read out and automatically save into K518, then it won't have the validty.
  13. The Following 2 Users Say Thank You to crazylou2017 For This Useful Post:
    habbyb (24th May, 2018), p1et (24th May, 2018)
  14. #385
    kaToo's Avatar
    today done kia sportage year 2012 smart key
    the tool won't extract pin via obd so i use other service for pin code
    and than use tool to program key 2min and all is ok
  15. The Following 2 Users Say Thank You to kaToo For This Useful Post:
    crazylou2017 (25th May, 2018), p1et (24th May, 2018)
  16. #386
    Feb 2013
    Quote Originally Posted by cosmiko View Post
    Smart Fortwo 450 2004 Year didnt work. Lonsdor didnt connect with car. I had to use MVP
    Hello all.Has anyone tested again? Thanks
    Best regards
  17. #387
    Feb 2013
    Smart Fortwo 450 2006 Year didnt work. Lonsdor didnt connect with car. I had to use Xentry das done 10 minute
  18. #388
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by taxo1965 View Post
    Interesting cause I am sure that like 2 weeks ago I saw somewhere on facebook that there was new update for Smart 450 but most interesting is that I cannot find it now It dissapeared like they knew it doesn't work and you proved it. Thanks for report mate
  19. The Following User Says Thank You to p1et For This Useful Post:
    taxo1965 (5th June, 2018)
  20. #389
    alfons37's Avatar
    Try peugeot 407 sw 2008, read pin code OK and programming key OK
  21. The Following User Says Thank You to alfons37 For This Useful Post:
    crazylou2017 (6th June, 2018)
  22. #390
    kaToo's Avatar
    Range rover evoque year 2013 program smart key ... conection OK vin detected but when try program smart key it says no communication
