Page 30 of 225 FirstFirst ... 2025262728293031323334354080130 ... LastLast
Results 436 to 450 of 3369
Thread: LONSDOR K518
  1. #436
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by clintezra View Post
    No it worked before...
    after the update it can’t get authorisation
    So fails!
    Key was ok as I used another tool!
    Not mate it put one key in
    And then when i uodated the tool
    Same car - add another key after the update and it failed -2017 ford ranger- id49
    You talking about same car?
  2. The Following User Says Thank You to p1et For This Useful Post:
    rojhat (21st June, 2018)
  3. #437
    Mar 2016
    South Africa
    The more we update this tool then
    the less it works.
    To be honest its the biggest
    piece of sh*t i ever spent my money on .
  4. The Following 2 Users Say Thank You to weza247 For This Useful Post:
    HeXeN (25th June, 2018), taxo1965 (21st June, 2018)
  5. #438
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by weza247 View Post
    the less it works.
    Can you please share your experience? What you tried and doesn't work? It will help others.
  6. The Following User Says Thank You to p1et For This Useful Post:
    PocketHero (21st June, 2018)
  7. #439
    p1et's Avatar
    Oct 2013
    VW Touran 2012 couldn't identify IMMO type. Did not like to play with it and try randomly (my guess was NEC24C64) so used other tool for transponder programming but remote programming OK and clear airbag error OK under NEC24C64 menu.
  8. #440
    Jan 2017
    USA ����
    ok so the toyota adapter things work now apparently
    if the link is not allowed then just google this
    use-lonsdor-toyota-smart-key-emulator-offline-calculation
    How to use Lonsdor Toyota Smart Key Emulator Offline Calculation
  9. #441
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Its only fir olders with eeprom. And you need to take off immo box. Newer immo data is in nec and lonsdor will not work this way.
  10. #442
    p1et's Avatar
    Oct 2013
    Audi A6 2013 keyless, 5 min done
  11. The Following 2 Users Say Thank You to p1et For This Useful Post:
    servicekey (23rd June, 2018), taxo1965 (23rd June, 2018)
  12. #443
    Apr 2017
    CITROEN BERLINGO 2004
    READ PIN CODE WITH TYPE 4 KLINE : OK
    PROGRAMME REMOTE KEY : OK
  13. The Following 2 Users Say Thank You to servicekey For This Useful Post:
    habbyb (25th June, 2018), p1et (24th June, 2018)
  14. #444
    HeXeN's Avatar
    Mar 2015
    Quote Originally Posted by servicekey View Post
    unbelieveable
  15. #445
    habbyb's Avatar
    Romania
    that's very good for psa
  16. #446
    Mar 2016
    jeep grand cherokee 2012 - Fobik keylessGo - function does not work -
    Synch smart key -
    I got a car to remove the lost keys - I got all the keys and now the function does not work KEYLESS GO - I make the function Synch smart key lonsdor writes everything ok - but KEYLESS GO does not work
  17. The Following User Says Thank You to alisher For This Useful Post:
    HeXeN (26th June, 2018)
  18. #447
    Feb 2013
    Chevrolet exspress(CAPTIVA) 2011 all key lost wait 12 minute programmed fail.VVDI Prog read BAD.Problem solve Orange5=Tango.Immo 9S08DZ60
    Passat B6 2006 USA kessy 95320 programmed fail
  19. #448
    HeXeN's Avatar
    Mar 2015
    Opel Insignia 2010
    pin read ok
    via chevrolet, type6 (bcm)
  20. The Following 3 Users Say Thank You to HeXeN For This Useful Post:
    p1et (26th June, 2018), PocketHero (26th June, 2018), taxo1965 (26th June, 2018)
  21. #449
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by HeXeN View Post
    Opel Insignia 2010
    pin read ok
    That's what I thought will work and wanted to try this as soon as I get opportunity after I tried Astra H but under Opel menu and no luck. Then I wanted to try under Chevy next time. Thanks a lot for testing it and for sharing info. So Astra J and other might work too.
  22. The Following 3 Users Say Thank You to p1et For This Useful Post:
    PocketHero (26th June, 2018), rola1971 (26th June, 2018), taxo1965 (26th June, 2018)
  23. #450
    habbyb's Avatar
    Romania
    Chrysler 300C key fobic read pin OK key programed failed .
    Bmw Cas 2 read key info OK key programed failed .
  24. The Following User Says Thank You to habbyb For This Useful Post:
    p1et (27th June, 2018)
