Rio orio (15th November, 2018)
Hyundai Veloster 2012 AKL
Program Key = OK
Read pin = Fail
If i helped please press the thanks button
PocketHero (13th November, 2018), Rio orio (15th November, 2018)
Hyundai Tucson 2006
add remote - ok
I did not try read pin
peugeot 2008 partner - pull pin and program key - OK
land rover discovery 3 - program 2 new key - OK
PocketHero (15th November, 2018), RIMKACHIP (14th November, 2018), Rio orio (15th November, 2018)
Lonsdor is the definitive machine
Opel Corsa c 2005 read pin and add key ok
Peugeot Partner 2003/4 read pin and add key ok
CItroen Berlingo 2003 read pin and add key ok
Vw Polo 2010 identify Immo error, nec 24c32 make dealer key and add ok
Vw Polo 2002 read pin ok, add key error
Renault Trafic 2008 add key ok
PocketHero (15th November, 2018), RIMKACHIP (15th November, 2018), sdnatlst (15th November, 2018)
Vauxhall/Opel signum 2005
tested all types
Read pin = Fail
Program key = Fail
Opel Meriva A read pin error. Add remote and Key ok
Megane 2012 - 4 button card - working with new proper card - programmed OK
Astra H convertible 2007 - read pin using type 3 - program using Astra H in menu - OK
i have a VW Caddy 2014 tomorrow - will lonsdor do it? or shall i use VVDI keytool to copy transponder and learn remotes with VCDS? - its my first VAG so im new
PocketHero (15th November, 2018), rola1971 (16th November, 2018), sdnatlst (15th November, 2018)
CItroen C4 gasoline with BSI JCI 9664058780 9664059180 soft 0934 ,
Pincode found by obd2 TYPE1 OK !
PocketHero (17th November, 2018)
Any new updates lately lads!
