Why is this option available?
Automat (22nd September, 2018), super jumbe (22nd September, 2018)
has anyone managed an Astra J ? 2013
i see engineer test page said had done Astra J 2012, however i cant find the option in menu, only Astra H?
hello I do one with SKP900 AKL in 10 minutes.
does anybody know which cas4 and fem versions is supportet ?
Opel Vectra B add key OK
307 Kline read pin add key ok
touran immo 3 add key ok add remote ok
opel Meriva 2005 read pin add key ok
807 2008 read pin add key ok
3008 2011 read pin add key ok
508 2012 read pin add smartkey
Jumper same as Ducato add key ok ( read pin by another programmer)
Synchro cas3 dme x6 ok
p1et (25th September, 2018), PocketHero (25th September, 2018)
2013 dodge ram 1500 did not work. I already had the pin code but still no luck...
2002 jaguar xtype not even availableEnded up using my autel worked flawless
Did you choose Kuga i menu or other model, because before 3 monts i tried to program on Kuga 2013 spare smart key and it give me no communication with car.
anyone used this tool to program an old range rover key in? as in photo
uses EWS system i believe, if not what is best tool to buy to do these? handy baby cloner or something do it?
