Page 51 of 226 FirstFirst ... 41464748495051525354555661101151 ... LastLast
Results 751 to 765 of 3377
Thread: LONSDOR K518
  1. #751
    sdnatlst's Avatar
    Aug 2011
    England
    ASTRA H, cannot read pin, security error
    tried various menu in IMMO under opel. one DID give a security code, but went to program and also FAIL, so unsure if code was wrong or it simply cannot program Astra H
    waiting for my MVP PRO to arrive next week to go back to customer....
  2. #752
    May 2013
    Quote Originally Posted by taxo1965 View Post
    Hi all.
    Toyota/Lexus Smart Key Emulators-All 5 emulators are ready now!
    we will test
    http://en.lonsdor.com/html/updatelog/162
    Is this a tested working solution now?
    Ford Ranger 2017 works perfect. 2 Mins done with ID49 / Onboard chip.
    New Ranger 2018 Failed to get Security.
    VW Jetta with CDC cluster Failed......
    VW Polo with Crypto 93C86 failed to read pin.
    Land rover 2013 SMart key add / all keys lost worked perfect in 1 min....
  3. The Following 3 Users Say Thank You to obeids For This Useful Post:
    habbyb (8th October, 2018), HeXeN (9th October, 2018), taxo1965 (7th October, 2018)
  4. #753
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    BMW E92 2008 CAS3++
    Eprom saved, CAS upgrade success, and so much was, couldn't add a key. Neither in car's or Lonsdor's slot...
  5. The Following 4 Users Say Thank You to PocketHero For This Useful Post:
    HeXeN (9th October, 2018), newone (7th October, 2018), ps80l (9th October, 2018), taxo1965 (7th October, 2018)
  6. #754
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by PocketHero View Post
    BMW E92 2008 CAS3++
    did you use any kind of external PSU? Or just the battery in the car?
  7. #755
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by jodge View Post
    Just the car...
    2004 Xsara Picasso AKL. 1 min with pin reading
  8. The Following 2 Users Say Thank You to PocketHero For This Useful Post:
    HeXeN (9th October, 2018), servicekey (9th October, 2018)
  9. #756
    jodge's Avatar
    Mar 2017
    lucky bastard
    (i know you have eep bakcup)
  10. #757
    grzyb26's Avatar
    Jan 2012
    Mitsubishi outlander sport USA 2012 add keyless ok
    Astra J read pin ok
    Mazda 6 USA 2016 not work
  11. #758
    Jun 2018
    England
    Quote Originally Posted by sdnatlst View Post
    Astra H 2004
    Pin = Success
    Program Key = Success
    make sure the car battery isn't low, i had to use a battery booster connected to get the pin and also make sure you use the correct key pcf7941 chip inside
    If i helped please press the thanks button
  12. The Following User Says Thank You to paulsta For This Useful Post:
    sdnatlst (10th October, 2018)
  13. #759
    sdnatlst's Avatar
    Aug 2011
    England
    thanks, when you chose astra H in menu to read pin, before you connected battery booster did you also receive an error?
  14. #760
    Jun 2018
    England
    Yes as the battery didn't have much charge, the pin you have will be correct, it took a couple of attempts,
    Sent from my Pixel 2 XL using Tapatalk
  15. The Following User Says Thank You to paulsta For This Useful Post:
  16. #761
    habbyb's Avatar
    Romania
    Hello , someone did Kia-Hyundai keylessgo ?????
  17. #762
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by habbyb View Post
    Good 'til 2015
  18. The Following User Says Thank You to PocketHero For This Useful Post:
    habbyb (15th October, 2018)
  19. #763
    Jun 2018
    England
    Read pin using type 3
  20. #764
    Jun 2018
    England
    Another Astra H 2007
    Read Pin = Success
  21. The Following User Says Thank You to paulsta For This Useful Post:
    sdnatlst (11th October, 2018)
  22. #765
    sdnatlst's Avatar
    Aug 2011
    England
    when i read astra H pin other day, it read "Anti theft pin" then the code, i wasnt sure if it pulled stereo code or something different.
    anyway i am trying again saturday, with the pin it read, to program key using battery booster, will report
