Blade or smart?
Blade or smart?
smart key all key lost
Opel Corsa E 2015
with 1 working key
- read pincode FAIL (no communication)
- without key it switches ignition on for 3 seconds then off...
Insignia 2011 petrol
1 working key
- read pincode fail
p1et (19th June, 2018)
Peugeot 307 2005
read pin code type4 k-line FAIL
it reads vin ok
peugeot 807 retreive pin code failed
This tool work for pin work only for CAN vehicles. Why you try reaad on VAN
on CAN also not work. this updates are fake
p1et (20th June, 2018)
How it reads pin without working key on c4?
taxo1965 (20th June, 2018)
If k line worked it would be great. But if it fels i economy mode dring this it woud be...
No it worked before...
after the update it can’t get authorisation
So fails!
Key was ok as I used another tool!
Not mate it put one key in
And then when i uodated the tool
Same car - add another key after the update and it failed -2017 ford ranger- id49
