First of all where you will get this new key with part codes.
Renault ECU tool / IO terminal / A.S.W
habbyb (17th April, 2018)
Today i’ve learn key on fiat ducato 2008. Lonsdor can’t read pin!
first try by lonsdor and don’t see the transponder. I don’tnknow the chip was normal id48 or vw config. Forget to take my tango!
then i load the file tagtool and make a key but don’t have write the dump back. Only configurtion of the chip.
connect again lonsdor to the car and then learn the key good!
When I help you
PUSH on +THANKS and REP or
rob h (16th April, 2018)
i know that you need first precode the chip. i’ve avdi with fiat keyfunction, tango with fiat maker but i want to know if lonsdor can do job whitout other tools.
lonsdor don’t precode the chip not or i’ve use wrong id48 chip. But if you also have try then you needs precode the chip first and then you can learn the chip with pincode.
When I help you
Hello mate , same in this video https://www.youtube.com/watch?v=Ov4W2u5hAOA
Something is with your eyes buddy.
Its not xc90 key
Those in video you can get .
Xc90
Maybe at dealer only
instakeys (17th April, 2018)
read pincode psa immo 3 fine
servicekey (21st April, 2018), taxo1965 (20th April, 2018)
Check this youtube playlist about lonsdor K518 guide:
https://www.youtube.com/watch?v=gwiQ...pZVaRU_ChhdA68
hope it can help you!
Bmw failed. Unknown cas version error. # 9147204
Connected vvdi2 and was done in under one minute. Cas was not encrypted.
