Hi all
i have set up my box with 28 d astra on one satteliter no problem fine now i want to set up my other dish motorised.
what will i need to do to set up all the other sattelites and how do you switch from lnb 1 motorised to lnb 2 fixed astra?
Hi all
Vu solo 2. , motorised 1 metre dish
you dont need to do anything setup the other tuner as Simple - Positioner and then enter your longitude and latitude details if your Motorised dish has been set up with USALS anyway.
After that just install a Motorised channel list
Ukhammy2015 (15th December, 2016)
Is this list the catseye list and where does that go onto thebmemory stick or a dir on receiver if so what directory please
Ok because i am new i wanted to make it clear what i am asking
Vu solo 2 set up with tuner B set to a fixed dish on 28 with the q skin all working fine
i now want to set up my motorised dish to tuner a and this is what i am stuck on.
i have downloaded a list called cateye which has all the satellites on
Waht i require help on is
a how to set up tuner 1 for motorised on my solo 2 ? are there any guides for this ?
the cateye file where do i copy this too is it the memory-stick or the main directory on the vu solo if so can someone tell me what directory please
the prgogram i am using to transfer my files to solo is the dcc dreambox control centre
thanks in advance
This well written guide for your channel list: http://www.digital-kaos.co.uk/forums...t=dreamboxedit
To setup tuner 2 for the motor dish
Goto www.dishpointer.com
enter your postcode........and get the Long & Lat (see photo bottom left)
press menu on the remote setup/service searching/tuner config/tuner B/press sideways on the remote till you get simple
then enter the Long & Lat east or west
Then go to BBC1 on your channel list (28.2) the dish will move
if your dish is setup right you should get a picture
Thanks p&d
i may be getting confused here tuner b is up and running as a fixed sat fir astra 28
what i cant do is set the postioner up fir the mutl sat option on tuner a
this is my current set up
also where do i put my cateye files directory unsure and do these go on memorystick or dir of solo when i ftp
digicon (15th December, 2016), Ukhammy2015 (15th December, 2016)
I only have one channel lust at monent 28 east
I did look at the link digicon recomended but this realted to a drambox and also channels on 28 e and i have them
am i right or wrong with my thinking p&d
Vu Solo & Dreambox both use the same channel list
download this....http://www.digital-kaos.co.uk/forums...=1#post2886827
the attachment i have put in this post at the bottom......use this to upload the channel list
unpack it/run it
enter the box IP address name password
then connect and upload the channel list
digicon (15th December, 2016), Ukhammy2015 (16th December, 2016)
ok thanks p&d and digicon i have done as explained so i will now have the sats bouquet on my receiver
thanks to all who have helped me a week ago i had never used a linux receiver and with your help it is up and running cheers great group
