Results 1 to 15 of 26
    Feb 2013
    Dublin
    Default Toyota Prius 2010 ZVW30 smart key
    I tried, by reading other posts, about same topic to understand what to do about this car when all keys are lost.
    Some one claims there is no box in dash, behind blower, then some one says that keys are in transmission module and
    also that smart b0x needs to be reset ass well. Can we try to clarify this and have it like guide for future, please.
    I Found box behind blower, ( 89784-47010 in part catalogue it says Computer, Immobilizer code)
    When I import dump from it's 93c46 to AVDI dump tool, It recognize it like ID box and offers me to reset keys or virginize and
    tell's me that smart module needs to be reset, I didn't remove module because was late, suppose that is 89990-47060 and its located
    behind glove box (correct me please if i'm wrong). Will teke it out today.
    Can some one tell me how to reset smart module, by AVDI or ... ?
    Any help will be highly appreciated!
    rola1971's Avatar
    Jun 2014
    Dublin
    what key programmer you have?
    100% for you help avdi or skp900
    it have hunction all key lost
    good luck
    Feb 2013
    Dublin
    Quote Originally Posted by rola1971 View Post
    good luck
    So You telling its possible to do that car via OBD with SKP900?
    I tried with AVDI, AD, Zed Full, lost 2 hours in trying.....
    Ask people and no one is sure how to do this car.
    rola1971's Avatar
    Jun 2014
    Dublin
    lexus smart key i doit 100%
    prius i dont try but it is to same system
    Nov 2015
    South East Asia
    https://youtu.be/TxREyI6lqF4
    Sent from my SM-G935F using Tapatalk
    Nov 2015
    South East Asia
    See if this link helps you
    Feb 2013
    Dublin
    Thanks, it looks interesting.
    Some one have this Hotwire programmer? Is it works really?
    Till now I only menage to reset immobilizer on some LandCruiser and Hilux.
    Yaris 2006 onward, Avensis 2009 - 2010, Prius with slot key, Corolla 2009, few of each, no luck with OBD reseting with AD or AVDI or ZF only adding keys work, but when is no keys, all of them I done by removing immo box.
    I will be really happy to find some device which really work, to make my life easier.
    Tomorrow will go back on that Prius and will post what I have. (probably more questions)
    ttzag's Avatar
    digital-kaos
    remove id box and smart box read eeproms and put it here someone will reset it to you , then use obd to add keys .
    i used for it T300 , it give you output code to inter input code (use AD calculator for it ) then job will done
    Actions speak louder than words
    Dec 2012
    EU
    Is it not like.. take smart box out and read eep.and add key by dump.
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    Jul 2016
    New Zealand
    Did your car have slot for smart key? If you have it, then your car older version and has ID box.
    My was without slot (just a push button) and I have to reset gearbox ECU and Smart key ECU to program new key.
    Feb 2013
    Dublin
    I will take Smart Box if I can find it, It should be behind glove box, but is not there.
    There is Power management control, MPX body and Transmission control which some one all ready mention.
    In Transmission control I dont see eeprom....
    Ideas?
    Dec 2012
    EU
    In yaris smart Box was on driver side above throttle pedal if that helps
  13. #13
    Feb 2013
    Dublin
    Started car last evening.
    Will post after I put back all together.
  14. #14
    Jul 2017
    UB, Mongolia
    Quote Originally Posted by pundravac View Post
    pundvarac,
    already a year since your last post.
    or you still did not put back all together?
    Could you tell what did you do with this smartbox?
    I have same problem.
  15. #15
    Jan 2017
    USA ����
