Results 1 to 9 of 9
    Jun 2012
    Default xprog china v5.55
    hello i have proplem for instal xprog v 5.55 not work with me .
    Aug 2015
    your xprog is fine, pc/drivers problem, first you need adobe reader 10, second change com port to (if you can to com1 or com2) , reinstall or clean install ftdi drivers if nothing helps install another OS on that pc or change computer...
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    you might find you have to pick comm everytime you use it
  4. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    doctore (19th December, 2016)
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by ibrasport View Post
    first install adobreader then activate the license and then transferred folder== iXprog5.55 soft = = in the C partition only , and then it will work if cannot work reinstal windows
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    just search for the no dongle version and use it no install needed , and is your firmware for ver 5.55 and is correct adobe installed
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
    Oct 2016
    xprog v 5.55
    you need check your system.. this one can be only work at XP32bit or WIN7 64BIT windows
    and make sure your driver is ok..and com port.
    NO ANTIVIRUS!
    if helped you.
    please click THANKS
    Jun 2012
    i chek all no luck istill need help for fixed it thx
    Feb 2017
    suriname
    hi
    i also have problems installing the software
    from research i have found out i am missing a pacth file wich i did not get on the cd with the box
    so i can not install the drivers for the box
    can any one help me resolve this isseu ?
    thanks and kind regards mehmet
  10. #9
    Quote Originally Posted by mehmet becker View Post
    hi
    upload your software come with your hardware.
    I know what to look for if you have not resolve.
