your xprog is fine, pc/drivers problem, first you need adobe reader 10, second change com port to (if you can to com1 or com2) , reinstall or clean install ftdi drivers if nothing helps install another OS on that pc or change computer...
you might find you have to pick comm everytime you use it
doctore (19th December, 2016)
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
just search for the no dongle version and use it no install needed , and is your firmware for ver 5.55 and is correct adobe installed
Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
xprog v 5.55
you need check your system.. this one can be only work at XP32bit or WIN7 64BIT windows
and make sure your driver is ok..and com port.
NO ANTIVIRUS!
if helped you.
please click THANKS
i chek all no luck istill need help for fixed it thx
hi
i also have problems installing the software
from research i have found out i am missing a pacth file wich i did not get on the cd with the box
so i can not install the drivers for the box
can any one help me resolve this isseu ?
thanks and kind regards mehmet
