Could you write more details, numbers srs unit ...
Best regards.
Dragon
andresvargas704 (22nd March, 2017), auto ele (20th December, 2016)
98 033 804 80 this is the peugeot serial number
0285 011 402 bosch
Your cleared file, report back, if ok rep+thanks.
Best regards.
Dragon
thanks for your help!
the file is not ok no dtc but the air bag light its still on do you have ather solution?
Try this ...................
Best regards.
Dragon
thanks again i iwill try it and i post back
it doesn't work the crash its still there do you have an ather solution?
It from tested srs unit, it should work, report back.
Best regards.
Dragon
y post new thread test ok
it works perfect!!!! thanks a lot !!!
My last or from lpv2010 ?
Best regards.
Dragon
the last one works perfect!
dragon100 (21st December, 2016)
hello can you dragon pass me the password for the last one thank you +rep
