Hi!
I have a Audi A6 with crash data 0285010856 4H0959655C - 95640 dump is attached.
If you can remove crash data for me please.
Thanks!
Hi!
Thanks!
First try clear via vcds or Launch, then try and report.
Best regards.
Dragon
bruceu (21st December, 2016)
Big thanks!
Now the car on the painting.
When you connect the unit to report the results.
Thanks!
Recorded, installed on cars, but still gives an error "block error" (
Scanner is not erased.
That read after installation on cars.
.... I can not find how to attach a file (
This is a dump.
multiplex1976 (17th May, 2019)
Try and comment!!!
bruceu (22nd January, 2017), groove (5th February, 2017), Le-Mans (12th November, 2019), samranisimo (29th January, 2017)
Thanks!
Test
All ok!
Thanks!
groove (8th February, 2017)
Could you share the PW please thanks in advance
Hi Bruceu,
Liked to know is it possible to swap 95128wt EPROM of a water damage airbag module 4H0959655H into a used airbag module in order to avoid coding of module.
Hi!
I can not think.
In 4H0959655H EPROM 95640
Please Pass me to PM. Thanks!
can give me password?
Please can you give me the pass
Hi, please can me pass
