populating epg
Results 1 to 15 of 22
Thread: populating epg
    Jan 2012
    Sunny Morecambe
    Default populating epg
    is there a way i can populate several epgs for different sats? like the main one on 28 but id also wont stuff like 19 and 16 and 13 populating but not sure which addons to use
    digicon's Avatar
    Either Crossepg or EPGimport can do what you want via the Rytec downloads, Just be careful as your running a Vu solo with it only having a very low power CPU asking it to download quite a few different EPG's could end up with errors, I would suggest you try with just 28.2 east and 19.2 east as a start see how the vu handles the download and then gradually increase the downloads 1 at a time until you think it may be at its maximum.
    Just for info if you are on 19.2 east and leave the Vu on one of the Sky Germany channels the EPG will populate fully over a couple of minutes itself
    Jan 2012
    Sunny Morecambe
    thanks mate, will it stay populated or ? ill have a look at this rytec downloads. cheers for your help
    digicon's Avatar
    The EPG from the German Bouquet will stay in ram until you either switch off or reboot or move to another satellite, the more permanent solution would be the rytec download
    Jan 2012
    Sunny Morecambe
    yeah my cross epg isnt updating rytec, so going to have a search around for this epgimport plugin. had this box a couple years and still learning, god help me when i upgrade in a few months haha
    Jan 2012
    Sunny Morecambe
    edit:: crysis aveted, after some messing around, got it to work, had to use an updated rytec file
    digicon's Avatar
    Jan 2012
    Sunny Morecambe
    cheers that starts, downloading them but even 28 wont download, always gets stuck on parsing, not sure if my box needs a full reset read something about a swap file for older boxes and downloads, not sure what it all meant though haha
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    What box exactly are you using I know you use vix so where are you downloading the epg to media/hdd or media/usb or internal flash.
    Check menu>set up>system>epg>settings>epg location press left or right on d pad to change location as this should not be set to internal flash as it will fill up and create problems. So use whatever you have fitted usb or hdd whatever you have mounted to box. hth
    digicon's Avatar
    You would certainly have to use a swap file with a Vu Solo it does not have the grunt factor to deal with all the extra processing on the EPG side
    Jan 2012
    Sunny Morecambe
    i give up, got 28 to do now with a sawp file but rytec providers constabntly fail, here is last log
    04/01/2017 13:28:52 HTTP Get (host:rytecepg.ipservers.eu, port:80, page:epg_data/rytecxmltv-UK.gz)
    04/01/2017 13:28:55 No more url available
    04/01/2017 13:28:55 Error downloading/parsing channels file
    04/01/2017 13:30:17 SIFTeam CrossEPG Downloader 0.8.1+gitrAUTOINC+74902c5ad3 (c) 2009-2014 Sandro Cavazzoni (https://github.com/oe-alliance/e2openplugin-CrossEPG)
    04/01/2017 13:30:17 This software is distributed under the terms of the GNU Lesser General Public License v2.1
    04/01/2017 13:30:17 Interactive: OPEN cmd received
    04/01/2017 13:30:17 EPGDB opened (root=/media/hdd/crossepg)
    04/01/2017 13:30:17 Clearing old aliases...
    04/01/2017 13:30:17 Loaded 0 aliases
    04/01/2017 13:30:17 Adding new aliases...
    04/01/2017 13:30:17 Completed
    04/01/2017 13:30:17 Interactive: OK action sent
    04/01/2017 13:30:17 Interactive: DOWNLOAD cmd received
    04/01/2017 13:30:17 Download channels from url: http://www.vuplus-community.net/ryte...-sweden.xml.gz (0)
    04/01/2017 13:30:17 HTTP Get (host:www.vuplus-community.net, port:80, page:rytec/rytec.channels-sweden.xml.gz)
    04/01/2017 13:30:18 Deflating rytec/rytec.channels-sweden.xml.gz
    04/01/2017 13:30:18 File deflated
    04/01/2017 13:30:18 Reading channels from /media/hdd/crossepg/crossepg.tmp.pKjomb
    04/01/2017 13:30:18 Read 1737 channels
    04/01/2017 13:30:18 Download channels from url: http://www.vuplus-community.net/ryte...-sweden.xml.gz (0)
    04/01/2017 13:30:18 HTTP Get (host:www.vuplus-community.net, port:80, page:rytec/rytecxmltvnordic.gz)
    04/01/2017 13:30:26 Deflating rytec/rytecxmltvnordic.gz
    04/01/2017 13:30:31 File deflated
    04/01/2017 13:30:31 Parsing /media/hdd/crossepg/crossepg.tmp.l4feL1
    04/01/2017 13:33:29 Interactive: QUIT cmd received
    04/01/2017 13:33:29 Read 56112 events
    04/01/2017 13:33:29 Failed to parse /media/hdd/crossepg/crossepg.tmp.l4feL1
    digicon's Avatar
    personally i just think your wasting your time the Vu Solo just does not have the processor power to handle multiple downloads as well as carry on doing its own main duty as a satellite reciever
  13. #13
    Jan 2012
    Sunny Morecambe
    found the problem, the problem is the version of vix its in the known troubles section, trouble is i cant go any higher because of old box, going to try find a black hole, stuck with this box until march
  14. #14
    digicon's Avatar
    which model clone is it
  15. #15
    Jan 2012
    Sunny Morecambe
    im not too sure, iv downloaded 2 different black holes for v2 and v3, bot when i press reset, the red light comes on, the instantly turns to green loading the vix image i have installed, formatted to fat 32 so not sure whats going wrong, stupid old box haha
