Results 1 to 10 of 10
    Spain
    Default Toyota Land Cruiser 1HD-FTE Key programming
    Hi members
    Need to make a new key car doesn't start Land Cruiser HDJ100 (DTC B2799 present)
    I have tried to ad new key 4c to the immobox 89780-60100,try to synchronise 30 minutes with jump on OBD pin-4 to pin-13 without not succeed !!
    I note that someone before has try to read EEPROM on ecu 89661-60750 has marks to be soldering don't now if his corrupt
    Does anyone have both files ok?
    Many thanks
  2. The Following User Says Thank You to 4eprom For This Useful Post:
    yuli7805 (13th June, 2018)
  3. #2
    lion0304's Avatar
    Oct 2014
    Don't touch to ECU
    Write back your Original 93C66 to immobox and read as 16bits.
    Read your 4C tiris data and post. See picture tiris data need to adding key
  4. The Following 4 Users Say Thank You to lion0304 For This Useful Post:
    4eprom (3rd January, 2017), brahimdyag10 (1st March, 2017), shadab (15th January, 2017), yuli7805 (13th June, 2018)
  5. #3
    Spain
    I think I changed the files here goes the 16bit reading and the 4c data that is in the key
  6. The Following User Says Thank You to 4eprom For This Useful Post:
  7. #4
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by 4eprom View Post
    Here your key added.
    93c66 key added.rar
  8. The Following User Says Thank You to lion0304 For This Useful Post:
  9. #5
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    hi m8 it seems u know a lot about toyota immo maybe u can help me here plz
    i have a quantum it scans as a hilux 2.5 Diesel turbo 2kd engine . i have tried a lot of files for immo off but no luck on the key is a G i dont know if it makes a difrance but last file i got was virgin , load it and only have injector error so coded injectors firts start it fires up and dies then i have b2799 error immo box is unpluged
    immo eror only apears after first start and stay there
    ECU number 89661-26B30
    number on pc board 175822-666#
    regards
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
  10. #6
    Spain
    I'm going to try it and then I will reply...Thanks
  11. #7
    Spain
    No luck!!!! the light still flashing ,after pin4 with pin13 and 32 minutes connected !!!!
    Do you have another idea ....?
  12. #8
    lion0304's Avatar
    Oct 2014
    4C transponder no need sync by 4 + 13. That is for 4D chip.
    CHeck transponder coil around ingnition lock, wiring, fuse.
  13. The Following 3 Users Say Thank You to lion0304 For This Useful Post:
    4eprom (16th February, 2017), shadab (15th January, 2017), yuli7805 (13th June, 2018)
  14. #9
    Spain
    THANKS was the transponder coil around ingnition lock..
  15. #10
    alclot's Avatar
    Melee Island
    Hi mates,
    Can anyone help with virgin dump for ecu same reference please?
    Thanks a lot in advance
