2012 isx15 CM2250 EGR
Results 1 to 4 of 4
    Jan 2017
    Default 2012 isx15 CM2250 EGR
    Need some guidence, Due to my limited knowledge,
    2012 ISX15, CM2250. Need to block off Egr by a blocking plate. instead of unplugging or going thru a full delete. this truck has a butterfly
    instead of the older egrs which is sealed.
    what would be a good point to block it at? may be at cooler inlet?
    size of plate if any one can shed some light on.
    Or may be i am totally off track.
    Jan 2014
    If you block off with a plate you are going to receive fault codes I would think
    Mar 2017
    if you tune it properly you dont have to do anything. granted it isn't stuck in the open position. then i would put some sort of blocking plate. could even be at intake so its easier to plug
    Junior Member adftuning's Avatar
    May 2017
    Bilbao. Basque Country
    i have tested delete software solution for this model, contact me if need my help.
