Results 1 to 3 of 3
    Dec 2010
    Default Swap Golf 2008 dash with 2012 dash
    Hi all,
    Do you think it will be possible to replace a dash of Golf 2008 contains 24C32, with another dash contains 24C64 from 2012 ?
    Thanks for any idea.
    Oct 2014
    Netherlands
    Sure no problem.
    You simply need to read immo from the orig cluster, and write it to the new cluster.
    If the old cluster is not VDO NEC but for example VDO Micronas then you need to learn new transponders as well.
    Please specifiy the exact partnumbers of both the original dash and the new one.
  3. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    junmab (7th January, 2017), sagie1zn (5th January, 2017)
    In EEP
    FVDI VVDI2 can you help or Abrites �� .....only in eeprom not posible save ESP coding before swap cluster!!!!
  5. The Following User Says Thank You to vasa For This Useful Post:
