Results 1 to 12 of 12
    Jul 2013
    Default Renault Twingo IR key
    HI
    Please can you help me whith pin code Renault
    Twingo IR key .
    Label letter inside a key
    is lose.
    I have read optical IR receiver roof pannel 93c46.
    Need to find pin code from dump
    THANK YOU
    Jul 2011
    Iasi, Romania
    Hi, what is the problem with the key? Can you post a picture with the pcb?
    I repaired a receiver unit some time ago and the issue was humidity in receiver module.
    Or your key is damaged?
  3. The Following User Says Thank You to ciprishor For This Useful Post:
    oltiolti (10th January, 2017)
    Jul 2013
    Yes key is damage
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Your solution in link in txt file.
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
  7. #5
    Jul 2011
    Iasi, Romania
    Maybe this guy can help. It seems he is able to calculate pin from dump.
    http://www.digital-kaos.co.uk/forums...wingo-Need-PIN
  8. #6
    Jul 2013
    Thank you for reply and support
  9. #7
    Jul 2013
    Problem not solved.
    I am waiting for reply .
  10. #8
    dragon100's Avatar
    Jan 2012
    Make photo oval sticker from passenger's side like in my link and post here.
    Best regards.
    Dragon
  11. The Following User Says Thank You to dragon100 For This Useful Post:
  12. #9
    Jul 2013
    Renault Twingo target data
  13. #10
    lpf01's Avatar
    Oct 2013
    Check key fob inside, code usually stamped into the plastic, not on a sticker.
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  14. #11
    dragon100's Avatar
    Jan 2012
    Quote Originally Posted by oltiolti View Post
    Hi, try with program from link first C068 then F024346 or first 068 then 024346. I can't try because I'v got win 7 no xp. If not work check your car have immo box or uch and then read eeprom or mcu from immo box or uch then somebody help you.
    Best regards.
    Dragon
  15. #12
    szkeptmen's Avatar
    Jan 2010
    Hungary
    Is there a way to re-use IR keys ?
    I have some of them, need to help others...
    What is the procedure - if exist ?
    Polak, wegier dwa bratanki i do szabli i do szklanki
