Results 1 to 12 of 12
    Junior Member Ukhammy2015's Avatar
    Sep 2015
    Default Can you run Kodi on a vu solo2 box
    Is it possible to run kodi on my solo vu2 box and does it work ok.
    i have had the box now about three weeks and exploring what else it can do
    Vu solo 2. , motorised 1 metre dish
    digicon's Avatar
    Yes you most certainly can, A lot of images have it pre-installed such as blackhole but others you may need to download it from the plugin section
  3. The Following User Says Thank You to digicon For This Useful Post:
    Ukhammy2015 (7th January, 2017)
    Sep 2015
    thanks for repy digicon i am using openvix would you know what plugin i wold be best to go for
    digicon's Avatar
    I dont use Openvix but in the OpenATV image its in the extensions download from the plugin menu
  6. The Following User Says Thank You to digicon For This Useful Post:
    Ukhammy2015 (8th January, 2017)
    Sep 2015
    i have found it and installed and loaded pulse it dos not appear to be working well thouth i thought it would work better than my kodi box with the spec of the receiver.
    i run a film music etc than i get a black screen ?
    this is the first time i have gone into the extensions area being new any recomendations on other ext to load on.
  8. #6
    digicon's Avatar
    I believe it works better with a USB drive connected as well to cache etc..
  9. The Following User Says Thank You to digicon For This Useful Post:
    Ukhammy2015 (9th January, 2017)
  10. #7
    Sep 2015
    yes i have a uisb attached i assume you do not have to set up within kodi to cache here i assume th solo does that
  11. #8
    Sep 2015
    Still cannot get kodi to run with usb drive attached open a programme and screen goes boack have to reboot solo
  12. #9
    smokey08's Avatar
    Essex, UK
    I have it on my solo2 and it works ok.
    I also run openvix and I installed the "vuplus-kodi" plugin from the downloads menu. I then followed a guide posted by forum member cunny and loaded the paradox build into kodi.
    I dont use a usb drive at all.
  13. The Following User Says Thank You to smokey08 For This Useful Post:
    Ukhammy2015 (13th January, 2017)
  14. #10
    Sep 2015
    smokey08 thanks for the info i have done similar to you i think do you have the guide posted by cunny i loaded pulse
  15. #11
    Sep 2015
    can i get some info i have installed kodi on my vu2 solo box but want to remove it and try installing it again it kust is not working at all just hangs
    any help please
  16. #12
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    In the past while testing kodi on box I have found that fresh reflash is best way but make sure you back up any files you might need before doing so.
