Results 1 to 7 of 7
    Jan 2017
    Default TM5402HDM3C1 Reciever
    Hallo Everyone. I have this new reciever and I am trying to reciever tv channels from Intelsat 907 at 27.5 West. So could any one give me any guidance as how to go about this. I am a total
    novice at this as I expected to just plug and play. But it seems not. So thanks in advance if you
    can help. I will try and thank you for any help received if I can work out how to do that, as I say a complete beginner.
    digicon's Avatar
    You need to Patch the receiver first with the latest firmware which can be found here: TM5402HD M3
    Once the receiver is patched do a scan for the channels on 27.5? west and then on each channel you want to view you type 8280 into the remote this will bring up the BISS key menu, you can now enter your key which i have attached to this post into any of the lines you want. Just enter the first 16 digits and then leave the rest as all 0's once you have done that exit and it will ask you to save press ok and your channel should open.
    Repeat this process for all the other channels you want to view, you dont have to enter the key again as an example if you put the Key in Line 1 then on every channel just highlight line 1 and exit and save for each channel
  3. The Following User Says Thank You to digicon For This Useful Post:
    Rustywadley (8th January, 2017)
    Jan 2017
    Many thanks for quick reply will try that
    Jan 2017
    Hi. Thanks to Digicon. All working well. Only one hitch, seems can't get Film4+1 and Channel 5. Says these are off. Any thoughts on this anyone. Thanks
    kidderminster
    Just been to 27.5w, can confirm that Film4+1 & CH5HD are on.
    You may have to add the said channels through (Edit Channels / Add Channels or get a up to date channel list.
    DEN
  7. The Following User Says Thank You to den1 For This Useful Post:
    Rustywadley (15th January, 2017)
  8. #6
    Jan 2017
    Thanks den1. Sorry it's all questions. How do I get the channel list?
  9. #7
    kidderminster
    The best channel list to get is one made / updated by William1, have a look on the net for other forums for the Technomate 5402 receiver.
    Den
  10. The Following User Says Thank You to den1 For This Useful Post:
    Rustywadley (17th January, 2017)
