Astra H key pre-code data - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    Hi can I ask where are the eprom renew files available from to renew these key?
  2. #32
    Quote Originally Posted by tehnosoftex View Post
    Thanks, do I need to write also the erom or is enough to write only eeprom. If I will reset protection from pcf7941 I will lose the erom also?
    Depending on key. Astra-h/Zafira-B/Corsa-D type key - no erom. For Astra-J, Insignia new type key -you need to write erom
  3. The Following User Says Thank You to exe123 For This Useful Post:
    tehnosoftex (20th July, 2018)
  4. #33
    P&D's Avatar
    For Astra H & Zafria B just write eeprom only
    Quote Originally Posted by Galee View Post
    There on the net on a few sites.....or you get them with the key re-newer you buy
    Files in the attachments
  5. The Following 6 Users Say Thank You to P&D For This Useful Post:
    Astrator (17th November, 2020), eliselis (14th November, 2018), Galee (27th July, 2018), klauss78 (24th May, 2021), PocketHero (23rd July, 2018), tango (22nd August, 2020)
  6. #34
    Nov 2017
    sorry work ok with dump posted by vvdi prog.
  7. #35
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by P&D View Post
    Do you need to remove 7941 chip from board and program with new dump to precode?
  8. #36
    P&D's Avatar
    No pal you need to solder 4 wires to the board then run the software = new board
    https://www.keyprogtools.com/images/...-Renew-Key.pdf
  9. The Following User Says Thank You to P&D For This Useful Post:
    super jumbe (17th March, 2019)
  10. #37
    Oktawian's Avatar
    Sep 2016
    Is it possible to virgin fob from chevrolet cruze 2010 ?
