Results 1 to 6 of 6
Thread: Help EZS W208
    marcolr's Avatar
    Apr 2010
    Default Help EZS W208
    Hi m8īs
    I have a problem with an EZS of a W208. Part number is 2085450108, it has 2 motorola 0D69J with mask ZC410699cfu (outside) and ZC410710cfu (inside). Both of them are erased (all FF) I donīt know why, the owner of car bring me the EZS and key because he canīt turn key.
    The key is one with motorola 0F82B (567.880.021) and I have the key dump readed with xprog.
    Could be possible make the files for EZS using the key data?
    If itīs possible, could someone help me with that?
    Thank in advance
    If my post was helpful press Thanks button!!
    Mar 2018
    UK
    I don't think that is possible to retrieve the info for EZS from the key
    How do you read 0D69J?
    marcolr's Avatar
    Apr 2010
    Quote Originally Posted by Manta1600 View Post
    I readed with xprog. I desolder from
    EZS, solder in a qfp 64 adapter and use an 8 Mhz crystal.
    Regards
    Mar 2018
    UK
    I read them with VVDI prog and never had a problem
    marcolr's Avatar
    Apr 2010
    Anyone can confirm me if itīs possible to make a Micro files for EZS using the key data? With the data of an EZS with same part number could be possible to modify this data with original key data?
    Gavra's Avatar
    Jul 2010
    Belgrade/Melbourne
    No, depending on the tools you have it may be cheaper to order blue key than to waste time with cloned tools......
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
