HI
Please can you help me whith pin code Renault
Twingo IR key .
Label letter inside a key is lose.
I have read optical IR receiver roof pannel 93c46.
Need to find pin code from dump
THANK YOU
HI
Twingo IR key .
THANK YOU
Hi, what is the problem with the key? Can you post a picture with the pcb?
I repaired a receiver unit some time ago and the issue was humidity in receiver module.
Or your key is damaged?
oltiolti (10th January, 2017)
Yes key is damage
Your solution in link in txt file.
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
Maybe this guy can help. It seems he is able to calculate pin from dump.
http://www.digital-kaos.co.uk/forums...wingo-Need-PIN
Thank you for reply and support
Problem not solved.
I am waiting for reply .
Make photo oval sticker from passenger's side like in my link and post here.
Best regards.
Dragon
Renault Twingo target data
Check key fob inside, code usually stamped into the plastic, not on a sticker.
Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
Best regards.
Dragon
Is there a way to re-use IR keys ?
I have some of them, need to help others...
What is the procedure - if exist ?
Polak, wegier dwa bratanki i do szabli i do szklanki
