Results 1 to 4 of 4
    toysoft's Avatar
    Nov 2008
    Default DM800HD: OpenPli 4.0 Triple Tuner ExtePlayer3 / GStreamer 1.11 IPTV 1000+ free FTA IP
    DM800HD: OpenPli 4.0 Triple Tuner ExtePlayer3 / GStreamer 1.11 IPTV 1000+ free FTA IPTV channels
    Description of the image :
    - Image compatible with DVB-S2, DVB-C, DVB-T and IPTV / Streaming, all in one image
    - Image optimized for Streaming and IPTV
    - GStreamer 1.11 for Streaming / IPTV and playback (VoD)
    - ExtePlayer3 for Streaming / IPTV and playback (VoD)
    - Pre-installed list of more than 1000 channels FTA IPTV / Streaming Free
    - Latest version of Python-pycrypto, new ca-certificates, dvbmediasink, e-alliance rtmpdump, overscan wizard, SSLv3 support, FFmpeg, mx3Ls serviceapp with EPG support, Flash extender PPanel, ffmpeg, exteplayer3, gst1.0-libav , Mediaplayer2, iptv player, subssupport, HLS segfault, Mediatomb, MediaPlayer2, SubsSupport, latest OpenSSH OpenSSH OpenSSL, and Jam 5.3.
    - Enigma2 of OpenPLi 4.0 of December 2016
    - Built-in Wifi support for the following chipsets in the image
    ~~~~~~~~Ralink RT73, RT61, RT3070, RT3370, RT5370, RT7777
    ~~~~~~~~Realtek 8712u, 8188cu / 8192cu
    ~~~~~~~~ZyDAS zd1201, zd1211rw
    - Integrated Addon Manager with the option of installing the following USB DVB-T Dongles/keys
    Abilis AS102-SKY (AS102)
    AverMedia Volar Black 850 (AF9015)
    AverMedia A835 / B835 (AF9035)
    AverMedia Tv Volar Green (AF9035)
    AverMedia Sky DigitalKey A867 (A867)
    Hauppauge Nova-T (DIB0700)
    Hauppauge WinTV Siano Ministick (SIANO)
    Pinnacle PCTV 74e (AS102)
    TerraTec Cinergy T2 (CinergyT2)
    TerraTec Cinergy T XE (AF9005)
    TerraTec Cinergy T XE v2 (AF9015)
    ~~Which of the following Chipsets
    AF9005 Chipset
    Chipset AF9015
    Chipset AF9035
    SIANO Chipset
    Chipset DIB0700
    Chipset AS102
    Chipset A867
    DM800HD OpenPLi 4.0 IPTV v21 with Triple Tuner installed (Japhar Sim) :
    PHP Code:
    https://mega.nz/#!IVF0nZRB!2u3gBn7ZbMZqxh_lHZS2RMItrKlglevfllwoQy1O0nM
    Jun 2012
    Can use on Sim 2.01 clone?
    digicon's Avatar
    Read the very bottom of the post these can only be used on (Japhar Sim) which means you would have to replace your SIM, personally get a better box altogether the DM800 and SE are so long in the tooth now.
    toysoft's Avatar
    Nov 2008
    It is right that the DM800HD is starting to be old, and the 4 caps have to be replaced ;o)
    But with the right software, that is composed and developped in the best way, the OpenPLi 4.0 IPTV image, the box is reborn and can easily work few more years, as well as incorporate Digital Terrestrial TV with a DVB-T Dongle, as well as IPTV, in extra to the built-in DVB-S2 Sat... I have so many friends who put back on their TV/Installation their "old" DM800HD that worked even better than the ZGemma they had bought later. It's crazy, I know, but I am sure you will agree that's the software that do all, then the hardware can cope with it if it's well built.
    TS
