vectra c odometer correction what tool?
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Mar 2014
    Default vectra c odometer correction what tool?
    hi all I have a Vectra c that needs odometer correction
    I have an obdstar x300m which I don't think will work but also have a carprog running v8.21 aoftware
    will either tool do it?
    if carprog can anyone give me any tips?
    cheers
    pepesound's Avatar
    Jun 2010
    Bulgaria-Radomir
    eeprom programmer and hands
    if i can solve your problem, please use Thanks and Rep button
    Mar 2014
    ok
    will my carprog do that then?
    I think I need a pdf or how to guide as it will be my first attempt?
    I take it I just need the clocks in order to make the change and de solder the corret eeprom?
    cheers
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Carprog should do it
    Sep 2015
    Carprog is ok for the job.
    Vectra C has 93c66 eeprom under the mileage display. Desolder the chip from board.
    Mileage stored also in ECU or PSG16(2.2DTI).
    Mar 2014
    So
    Desolder chip from dash and then my carprog clone should be able to do the job?
    When i do it il posg some pictures up before i go ahead to make sure what im doing is right or does anybody have a good link i can follow and see how its done?
    Cheers
    Mar 2016
    PIC FROM ENIGMA
    Mar 2014
    doest need de soldering or can it be done with the chip still soldered to pcb?
    is this the same process for astra h as I have some astra h clocks to practice with aswell
    cheers
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Desolder it mate
    Mar 2014
    Ok so desolder and read with eeprom reader
    Maybe a silly question but how do i know what way round to place eeprom in reader pins for car prog?
    And then how do i go aboutfinding where in the read the mileage is stored and editing it?
    Cheers
  11. #11
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Carprog will say what it is in km
  12. #12
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Eeprom pin 1 is either marked with a dot or if one side is wedged angle with it facing you pin 1 is left side
  13. #13
    Mar 2014
    What way round in the eeprom reader does the chip go or is it labelled/self explanatory when i try to read?
  14. #14
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by dkenny View Post
    cheers
    it is wrong astra H it is 35080
  15. #15
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Open your cable if it's not obvious and compare with this pin out
    Pin1 to pin1
