Results 1 to 11 of 11
    4
    Downloads
    6
    Uploads
    Default avdi Electronic Transmission Control (722.9)
    I would like to know if there is the possibility of making me virgin file that I can write without needing SCN coding
    workshop
    80
    Downloads
    15
    Uploads
    you can find file on abrites database,for scn need vin first 6 number
    parts.
    sw
    ehs number
    i can coding give
    4
    Downloads
    6
    Uploads
    Or is the reference to search on the part and is that there is not a way to bypass the scn coding
    4
    Downloads
    6
    Uploads
    Is that there is not a file that does not require coding scn
    And all the reference that I type in the database shelters I can not find
    yugo45's Avatar
    1,824
    Downloads
    9
    Uploads
    Quote Originally Posted by kentrinite View Post
    Yes all modules in MB have SCN coding.
    However if old module available and still communicating , you can Copy SCN coding from old to new with AVDI if you have License for 722.9 transmission.
    Aug 2016
    123
    Downloads
    9
    Uploads
    pleaz could some one explain coding scn.
    volismb's Avatar
    Feb 2016
    84
    Downloads
    Uploads
    Quote Originally Posted by hk06 View Post
    What exactly do you want to know about scn? The above answers already contain useful information already
  8. The Following User Says Thank You to volismb For This Useful Post:
    yugo45 (16th January, 2017)
    yugo45's Avatar
    1,824
    Downloads
    9
    Uploads
    It is Coding of Module according to vehicle order.
  10. The Following User Says Thank You to yugo45 For This Useful Post:
    hk06 (29th January, 2017)
  11. #9
    4
    Downloads
    6
    Uploads
    I would like to know if there is the possibility of making a blank ETC file saving its encoding or having a blank file with scn coding included
  12. #10
    56
    Downloads
    9
    Uploads
    If you have old unit , read go to adaptation read the coding and save it
    then put new unit make virgin and after go adaptation and put the saved coding
    I hope a made it clear
  13. The Following 3 Users Say Thank You to tech111 For This Useful Post:
    dritan (2nd February, 2017),nenadgorgi (28th January, 2017),volismb (28th January, 2017)
  14. #11
    Feb 2011
    balkans
    14
    Downloads
    Uploads
    if donor unit is same number you just transfer SCN coding string from old unit also win,ehs number.Also avdi cant renew 3 generation of ETC unit
    So avdi make flash of unit to renew and SCN code transfer from old unit just copy=paste
    for more info give us win,ehs numbe,donor unit number,original unit number
