Results 1 to 4 of 4
    Jun 2016
    Default Mercedes Vito W639 second key program
    I bought second key with the same nec 081 as one working, read secured 9s12dt256 from ezg, generate keys but 051 firmware because I only have 021 and 051. So new key run car but remote not working even not transmited because I check on freuqency metter. When I put nec procesor from good old key remote works. What I have to do?
    I post eprom from hc9s12 and generated files.
    Adam
    May 2010
    prob radio byte damage.
    you need good tool to fix this.
    and "NO" cant be done through dump.
    Jun 2016
    This could be that I program this 081 nec by simply china nec mercedes programer?
    May 2010
    is possible yes.
    but also some expensive tool have this problem.
