I would like to know if there is the possibility of making me virgin file that I can write without needing SCN coding
you can find file on abrites database,for scn need vin first 6 number
parts.
sw
ehs number
i can coding give
Or is the reference to search on the part and is that there is not a way to bypass the scn coding
Is that there is not a file that does not require coding scn
And all the reference that I type in the database shelters I can not find
pleaz could some one explain coding scn.
yugo45 (16th January, 2017)
hk06 (29th January, 2017)
I would like to know if there is the possibility of making a blank ETC file saving its encoding or having a blank file with scn coding included
If you have old unit , read go to adaptation read the coding and save it
then put new unit make virgin and after go adaptation and put the saved coding
I hope a made it clear
dritan (2nd February, 2017), nenadgorgi (28th January, 2017), volismb (28th January, 2017)
if donor unit is same number you just transfer SCN coding string from old unit also win,ehs number.Also avdi cant renew 3 generation of ETC unit
So avdi make flash of unit to renew and SCN code transfer from old unit just copy=paste
for more info give us win,ehs numbe,donor unit number,original unit number
