Results 1 to 5 of 5
    Aug 2013
    Default 2008 Mercedes B200 EIS not Cranking at times after lost keys
    W169 EIS, used VVDI to program keys and when I tried to crank, nothing, then I turned off and back to crank, it cranks. I have DAS to diagnose next time but curious to know if the job caused the problem.
    Customer now realizes it's acting up.
    Used SMOK to read it and carefully soldered and desoldered, the only thing I can think of is either flux causing this problem or the problem was already there before.
    Appreciate the support here!
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    I think you moved some microswitch out of position that determins where the key is...Try to reassemble properly and i think will be ok
    Aug 2013
    Microswitch? I did not think these had microswitches, can you please send image?
    Thanks!
    Aug 2013
    What is the best Flux to use that would not harm these sensitive circuitry?
    clusters's Avatar
    Mar 2015
    Canada
    Kester 951 is a good liquid flux, clean residue off with alcohol.
